Setting the timing on a 354 Hemi.
Discussion in 'The Hokey Ass Message Board' started by mjcolemo, Aug 29, 2011.
  1. mjcolemo
    mjcolemo
    I have a 56 Chrysler New Yorker with a 354 Hemi engine. When I bought the car it was in dire need of a good tune up. I have gotten through the tune-up and it helped the engine a lot. But when I go to set the timing on the engine, and look at the harmonic balancer for the timing marks I don't see any. I have the timing pointer arrow, but no mark on the balancer.
    Is that normal, and if so, how would you be able to set the timing to 4 degree BTDC? Do the balancer on the old Hemi engines come with a timing mark or do you need to mark it and time off that. The 56 service manual I bought isn't much help. Any help would be appreciated.
  2. Rob Paul
    Rob Paul
    That balancer should have a timing mark. You will need to fing tdc on #1 and make a new mark.
    Rob
  3. Right on, Rob.
    FYI, different year engines had different timing pointers. Parts easily get changed, mismatched, etc over 50+ years...
    As Rob said, finding TDC on #1 (with a piston stop tool) and marking the balancer is the sure way of doing it properly.
  4. mjcolemo
    mjcolemo
    OK, that's what I'm hearing from several people. Thank you for the input.
  5. Joey McGuigan
    Joey McGuigan
    I have the same engine with no pointer and a pretty boogered up balancer. I need help getting started. Any suggestions would be appreciated.
  6. flynbrian48
    flynbrian48
    It's a DeSoto, but similar enough use as an example. I replaced the dual points with a Pertronix, dropped the distributor back in at TDC on #1, fired as soon as I touched the key. I then timed it by ear, advance the timing until it kicks back against the starter, then back off a touch. It's simple 8E5D3484-ED3D-4296-A05E-CCF4CAEE6B00.jpeg but it works.
    73RR likes this.
  7. 73RR
    73RR
    If you want to check tdc just pull the #1 plug and drop in a long wooden dowel. As you rotate the ***embly...BY HAND... watch the dowel rise and fall and when it tops out and sits there a wee bit you have it. You can watch the rockers through the valve cover hole to determine if you are on the intake.
    INVISIBLEKID likes this.
  8. sdluck
    sdluck
    Hook a vacuum gauge up to manifold vacuum get it to max vacuum and back it off a little.
