Hot Rods Setting up the motor and box
Discussion in 'The Hokey Ass Message Board' started by panhead_pete, Apr 25, 2010.
  1. panhead_pete
    panhead_pete
    This week Im hoping to make a little progress on my A coupe before putting it into storage whilst I move to China.
    With some help we are Going to set a motor and box into the A ch***is and just want to make sure Im on the right track.
    Pinion angles the same for g'box and diff.
    Have flat head style biscuit motor mounts for the SBC so will put the weld on sections of these so they are flush with the top of the frame rail.
    The ch***is is stretched 4" from the firewall so will mount it so the dizzy just clears the firewall.
    Will have the front end is before so will make sure everything clears.
    Anything else I should be considering?
  2. panhead_pete
    panhead_pete
    Sorry to bump my own post guys but just need to check on this.
    Will also run a level both ways over the intake.
  3. elricho
    elricho
    2 degrees is what I would set the pinion at-same for the motor and box.
    Of course-dont set your 2 degrees of the carb face,imagine a straight line through the crank,if you know what I mean!
