Severe Bondo Abuse
Discussion in 'The Hokey Ass Message Board' started by Nads, Mar 29, 2010.
  1. Nads
    Nads
    from Hypocrisy
    Here's the doors getting done, what a pain, these things are heavy, even without the gl*** and vent windows.
    As you can see there's a bunch to do, but I'm getting there.
  2. youreviltwin
    youreviltwin
    from fl
    nice progress. subscribed.
  3. Zeke
    Zeke
    I wanna be just like Nads when I grow up!!
  4. all that work around the back window... where is the drain trough and exit tube now that the floor rotted holes are patched?
    keep up the mediocre work..:)
  5. Nads
    Nads
    from Hypocrisy
    It's not finished yet, I'm going to make a removable shelf that will have drain holes and tubes for the water to exit. The entire shelf was almost completely rusted away as was the inner structure and the gl*** pinch weld.
    Way to judge something before it's done.
  6. Nads
    Nads
    from Hypocrisy
    Oh yeah, I just got two door tops off of a 60 Chevy 2 door sedan to make donor pieces to fill the stretched tops from Southeast Chevy Parts. Their sawzall had taken a **** so I had to bring mine.
    There was a poor 55 Chevy 2 door sedan sitting outside that had been in a terrible rollover, it was a total loss, heartbreaking, but it looks like whoever was inside did survive.
  7. darkk
    darkk
    the Northeast has it's share of bondo beauties. I did one back in the early 70's. A 1965 Chrysler new yorker 4 door with the side flat from bumper to bumper. The guy I was working for said no new parts,fix it all. I said that's a lot of fixing. He said I don't care, bondo is cheaper than replacement parts. 3 days of pulling with a small pipe style guy-chart and 11 1/2 gallons of cheap bondo later. Car listed to one side but he didn't care. It was straight and shiney....
  8. Boeing Bomber
    Boeing Bomber
    I've seen a bodyman mix his Bondo on a piece of 36" masking paper, then tape it on the quarter like a diaper...(His words) then mud hog it smooth after it hardened, paper and all.....Turned and ran away...
  9. guitar man
    guitar man
    from Tulsa OK
    Just about the whole p***enger side door skin on my truck is made of bondo. I've got to get out and walk some salvage yards and see if I can find another door :(
  10. Toner283
    Toner283
    I may have missed this part but are you going to sink the windsheild gl*** or are you using impala gl*** or have you overcome that issue in another way?
    Looking better all the time.
  11. Tuck
    Tuck
    Tech Editor
    from MINNESOTA
    Naannna nnaaah na nun nah nunnna... Naannna nnaaah na nun nah nunnna... BAT MAN! Nads is on scene *BAM* *POW* *BANG* and a hammer form.... Rob'n the blind...
    -its kinda like a tattoo of a **** and balls on your head... sure it'll get covered up by hair... but... :-D
    Does this mean you know cat woman on a personal level? I alway dug that chick... If you airbrush catwoman somewhere in the box I'll come to terms with the call sign...
    The chop looks great Nads...
  12. Nads
    Nads
    from Hypocrisy
    Impala gl***, the easy solution, go back and look, it's all do***ented. The car needed a windshield anyway.
    Thank you Tuck for the compliments, it means a lot to me, out to the gay rodge I go.
  13. EyeballJohn
    EyeballJohn
    Years ago a guy pulled in my shop with a nice looking 55 Nomad the car was in primer but both rockers had some bubbeling on them, he had already purchased a new set of rocker panels just in case I had to piece a section in, I didn't look under the car yet the owner said he was afraid to touch the panel, so I said let me just knock it a little with a hammer to see what we hear well after a rap or two not only did the inner and outer rocker panel fall of but all the way to the rear wheel well came down, it seams who ever did the work before used paint rollers news paper and about 4 gallons of bondo to sculpt a new rocker,
    One Never knows whats lurking under the primer........ Be Afraid.... Be Very Afraid...... :eek:
  14. Way to judge something before it's done.[/QUOTE]
    post 3000 yaaaaaaah
    dint ya see i was standing there holding a beverage and trying to be helpful and the smily
    there was not a tone other than ribbing ya i like the work
    i have had issue with drains before make them large .....good luck
  15. crotex
    crotex
    from cuero, tx
    that isnt as bad as the junk that that ruben guy on here(wheredoldcarsr) trys selling in La Vernia Texas...he was about 10,000 times what the true value is too and its about 90 percent bondo when you buy anything form him
  16. You should ditch the Batman logo and put this on there.
  17. Nads
    Nads
    from Hypocrisy
    post 3000 yaaaaaaah
    i have had issue with drains before make them large .....good luck[/QUOTE]
    I don't understand Emoticons.
    I'll make the drains big, on my way to 10,000 posts.
  18. any water that finds its way into the box will collect at the point you are working unless it has a nosebleed stance ... areamentioned is future location of the bat guana
    but you ain't done yet so i'll wait and see .... he said smiling broadly
  19. Nads
    Nads
    from Hypocrisy
    Si comprende, I wonder why those drain hoses aren't being reproduced? What little that was left had turned into petrified liqorice.
    Onwards we go.
    First I tacked the doors shut then proceeded to do the frames, it was pretty tough, all I used out of those $80 sections was 2 two inch pieces. The pictures are pretty self explanatory, it's just a puzzle you gotta cut and weld. The vent windows, I predict, will be a *****.
  20. Nads
    Nads
    from Hypocrisy
    Lotsa damn rust in the front floors, just as expected and 'repaired' in the same method as other areas, i.e, roofing flashing, and tar.
  21. Nads
    Nads
    from Hypocrisy
    Outside for the first time in 4 months, parked next to the wagon the chop is apparent, the fenders are just sitting there, no gaps have been adjusted yet. I found another Dodge Polara grille that I can chop pieces out of to extend the ends to the fender's edges.
    I'm getting closer.
  22. NoSurf
    NoSurf
    Looking good Billie-Ray!!!
  23. Muttley
    Muttley
    I crack up everytime you post a picture of that house. People that live in those types of places dont usually drive rusty '59 El Caminos, I'm sure your neighbors love you. :D :D
  24. Nads
    Nads
    from Hypocrisy
    Nobody lives on either side, on the left I've never seen anyone, except the pool guy and lawn dudes and on the other, the couple divorced and they're both gone, the gr*** is all overgrown and I think their horse died.
    You can't see anything from the street at all, but when I drive the cars out of the gate it all becomes clear, the wagon, I'm sure, makes people whince in agony.
  25. Toner283
    Toner283
    Screw 'em.
    The chop looks really good outside from a few feet away. The proportions are dead on. roof vent looks good too.
  26. Muttley
    Muttley
    Awesome, scan the local Craigslist and pick up an old washer/dryer to stick on the front porch. ;) :D :cool: I cant wait to see this one finished.
  27. The ElCamino makes my underwear stickier every time I see it.
  28. Sweats
    Sweats
    Lookin good my brother..I have weekends off now if you want some help..or just have me stand around..HAHA...im good at that you know
  29. Cody Walls
    Cody Walls
    Is the wagon getting choped next ??????????????????????????????????lol everyone seem to be on me for not choping and hardtoping mine but when u get a chance think it threw and tell me how much work u think there is into choping and hardtoping a wagon since u have one there also .by the way the elki is looking awsome man keep up the good work!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
  30. Nads
    Nads
    from Hypocrisy
    The wagon's my workhorse, she's getting bad though. No chop on that, I can't imagine the work that would be involved.
