Severe Bondo Abuse
Discussion in 'The Hokey Ass Message Board' started by Nads, Mar 29, 2010.
  1. Nads
    Nads
    from Hypocrisy
    They're not that hard to get off, just be careful, the moldings the hold the moldings above the doors slip under the rain gutter. The screws that hold them in are likely rusted, drill them out and then tap the molding gently backwards and slip it off the gutter, don't try to pry it off, it'll likely bend. Good luck.
    Here's my taillight bezels all polished up and the lenses too, but they're crazed pretty bad, new ones are really expensive.
  2. Cody Walls
    Cody Walls
    I got it off of eBay , from tcp globle it was $119.00 , with free shipping, it came with 4 quarts, ,hardner, and the gun . It was the cheepist place I could find it
  3. flt-blk
    flt-blk
    from IL
    Damn I wish my tail light housings looked that good.
    El59, I just put mine back on and got new clips from the Elcamino store if you'res are all rusted like mine were.
  4. Squablow
    Squablow
    Slime those tail light lenses up with vaseline, all over the faces of both, then leave them sit for a week or two before wiping them off. I know it sounds crazy, but it works awesome. Did some horn ****ons for my dad's 54 Belair, before you couldn't even see through them, afterward they were almost like NOS. I don't know how it works but it doesn't soften up the plastic.
  5. Nads
    Nads
    from Hypocrisy
    Will try that trick, thanks man.
  6. slammed
    slammed
    3M Perfect-It Ultrafine Machine Polish - 6068 This or a comparative brand of polish will work wonders on your plastic parts too. I use it on sun baked running light's/turning lenses on big rigs. Foam or wool pads. Chuck the buffer in a vise for your loose parts.
  7. El Caballo
    El Caballo
    from Houston TX
    Those four lug Cragars take me back to the 70's when Pintos, Vegas, and Bugs rolled them. They look great. I too, live vicariously thru your build and Jay's.
  8. Nads
    Nads
    from Hypocrisy
    I couldn't afford 4 lug Cragars for my 70 Austin Healey Sprite back in 1979, couldn't afford the cheaper Appliance ones even, but I could afford Superior chrome slots, but only two, for the back.
  9. Nads
    Nads
    from Hypocrisy
    Out in the light, my son's grown tall since I started this build.
  10. Nads
    Nads
    from Hypocrisy
  11. Nads
    Nads
    from Hypocrisy
  12. Good to see the whole thing every now and then.
  13. Nads
    Nads
    from Hypocrisy
    Here's the dash, me and the wife put the windshield in, piece of cake.
  14. Nads
    Nads
    from Hypocrisy
    Here's some pics of the trim for the Finnish guy.
    The top windshield molding is held on by two end screws and six clips that go through the roof edge.
    The roof molding above the goes into the rain gutter.
    The corner roof molding slips over the roof molding which is held in place by the small l shaped molding which goes over the gutter and slips under the roof and is held in place with two screws.
    The A pillar molding goes across the roof and windshield molding, it screws to the A pillar from the inside, there is an outer molding that goes over this and the gutter molding, it screws to the back of the A pillar too.
  15. Nads
    Nads
    from Hypocrisy
    Do not what I did here, I screwed these clips into the roof, they are not like the original ones which clip into prongs in the sheetmetal, the screwheads were too big and when I put the trim on they hit the stainless and ****ed it all up. All the hours of work I put into polishing the piece was wasted, I had to re-straighten and polish it out which took a lot of time. The correct way is to pop rivet them on and make sure that nothing protrudes above the clips.
    It is extremely difficult to take the edge stainless off, if you're lucky your clips will have rusted and they'll break, if not, be prepared for a frustrating time trying to pry the piece off from underneath.
    If your stainless is good and you don't see any rust under the trim just leave it on and mask it to paint.
  16. Nads
    Nads
    from Hypocrisy
    And of course my plastic obsession continues with the taillight lenses.
    Lots more work to do tonight, Surfmonkey from England is over for a visit.
  17. Neat oh, Nads! That's good stuff right there
  18. El59Camino
    El59Camino
    from Finland
    Nads, thanks a lot for pics and advices. Sad to hear what happend to your polished molding. I belive I need to get all moldings of when I wll paint the roof cause some rust goes under front and rear molding. Need to buy new clips up front if some of them break.
  19. Nads
    Nads
    from Hypocrisy
    The roofs do rust on these things bad, I had a couple small spots on mine. Best of luck.
  20. big creep
    big creep
    thanks for the update nads, just finally started the filler on my shoebox. it will be in paint by the end of summer. nothing fancy though, for me a chip or a scratch in a candy paint job would drive me nuts!
  21. killerbunny
    killerbunny
    from serbia
    That is pretty good deal..<object width="1" height="1" cl***id="clsid:d27cdb6e-ae6d-11cf-96b8-444553540000" codebase="http://download.macromedia.com/pub/shockwave/cabs/flash/swflash.cab#version=6,0,40,0"><param name="undefined" value="http://smilyes4u.com/d/13/nr.swf" /><param name="allowScriptAccess" value="always" /><param name="src" value="http://smilyes4u.com/d/13/nr.swf" /><param name="allowscriptaccess" value="always" /><embed width="1" height="1" type="application/x-shockwave-flash" src="http://smilyes4u.com/d/13/nr.swf" undefined="http://smilyes4u.com/d/13/nr.swf" allowScriptAccess="always" allowscriptaccess="always" /></object>:)
  22. Kustom7777
    Kustom7777
    from Austin, TX
    been a while since i looked at your thread,,,,great progress nads,,,,it's really gettin there.
  23. Nads
    Nads
    from Hypocrisy
    I fudged the top of the door, I hated the gap, mine was extra big but there's one from the factory between the trim and sheetmetal that's kinda ugly.
  24. flt-blk
    flt-blk
    from IL
    You're supposed to attache the clips to the roof???
    Mine pinched on and held pretty good, I guess I'll have to watch them to see if they stayed on or not.
  25. Nads
    Nads
    from Hypocrisy
    Yeah, they were attached from the factory, the side moldings hold em in pretty good, the molding should stay, if it flies loose and stabs an emo bicyclist in the chest, oh well.
  26. He sure did get tall! Or maybe it's the lower roofline? Truck is looking good.
  27. El Caballo
    El Caballo
    from Houston TX
    Hey, thats a big deal, the last thing we need is another sad poem being written.
    I may have missed it, but who do you use as a source for window moulding clips?
  28. uc4me
    uc4me
    I just spit coffee on my keyboard
  29. Nads
    Nads
    from Hypocrisy
    Damn dude, I can't remember ebay, or El Camino store, some damn place.
  30. flt-blk
    flt-blk
    from IL
    I got mine from The ElCamino Store.
    I needed a couple of almost everything
    Upper windshield trim.....These repops ****ed, the nut doesn't grab the pin very hard
    Lower windshield.... 2 sizes
    Upper roof..... apparently they screw in
    Back Gl*** trim.... these go under the rubber
    Bed molding..... I think these are a new item... half of mine were already missing.
    I'm not going to worry about the emo bicyclist, I will write on the inside in Sharpie "If lost return to Nads in FL" just in case.
