Technical SGI block decode help?
Discussion in 'The Hokey Ass Message Board' started by Jim Lato, Nov 14, 2020.
  1. Jim Lato
    Jim Lato
    Would anyone be able to help me decode this engine?
    SGI 5.7
    D148
    Reman# 53324
    14093638
    V0419PJJ
    on the front of the block on the machines surface is
    GJE184015
    I appreciate it, I been having troubles finding info on this guy
  2. Mr48chev
    What the hell is an S G I?
    lothiandon1940 and partssaloon like this.
  3. Jim Lato
    Jim Lato
    SGI" was abbreviation for Spheroidal Graphite Iron which is the same as we call Ductile or Nodular iron
    Is what I learned
  4. doyoulikesleds
    doyoulikesleds
    its a 1987 to 1995 tbi engine
  5. Jim Lato
    Jim Lato
    Ya I got the basic info on it. I’m trying to narrow it down further
  6. grumpy65
    grumpy65
    Spheroidal graphite cast iron.
    Fancy name for ductile cast iron.
    Edit: Ok...................too slow.
    Jim Lato likes this.
  7. Jim Lato
    Jim Lato
    Another thing didn’t these have larger journals? Or are these a small journal
  8. squirrel
    The letters on the partial VIN are confusing...maybe that G is the number 6? that would make it a Cadillac?
    J is 1988
    E is Linden, NJ, but they were making front wheel drive cars in the late 80s, I think.
  9. Jim Lato
    Jim Lato
    Thanks squirrel, I’ll get a mag gl*** and look a bit closer tomorrow. Sure looks like a G so that would be very odd
  10. squirrel
    also the D 14 8 casting date means the block was cast April 14, 1988, while the 0419 ***embly date means it was ***embled 5 days later.
  11. lippy
    lippy
    from Ks
    looks like a traditional number. You old guys should recognize it right away, the GJE is a jet engine, General electric Jet. Manufactured in 1958. Used in gloster meteors. Exported to england during the Korean war.
  12. Jim Lato
    Jim Lato
    Now there is a patch of hair missing where I’m scratching my head [emoji23]
    VANDENPLAS likes this.
  13. lippy
    lippy
    from Ks
  14. seb fontana
    seb fontana
    from ct
  15. Mr48chev
    Casting number shows up a
    14093638 Small Block V8 1987-1995 350, 2 bolt or 4 bolt, roller or flat tappet cam, 1-piece rear seal
    That from this page https://www.chevy********.com/news/reference-chevy-engine-block-casting-numbers/
    Searching shows that that casting number was machined for roller tappet cams or had less machining and ran a flat tappet cam in trucks.
    V0419PJJ
    V Flint
    04 April
    19 19th day
    PJJ = not in the regular suffix codes, Possibly a truck engine?
  16. Jim Lato
    Jim Lato
    Thank you for you’re help. That’s kind of what I thought when I was looking up PJJ. I’m gonna see if the heads are any good
  17. Mr48chev
    Some sources say it started with 86 and others 87. The cam will probably tell you a lot though.
  18. Jim Lato
    Jim Lato
    By the cam? Tell me more
  19. Mr48chev
    From what I am reading Roller = came out of a car flat tappet = came out of a truck. That may not always hold true but might get you closer or send you in the right direction.
    Kind of like the 010 block in that it could come either with 2 bolt or 4 bolt mains depending on what rig it went in at the factory.
    When you check the casting numbers on the heads that might tell you more too.
  20. Jim Lato
    Jim Lato
    Ohhhh duh duh duh. Now I remember reading about this. It is a four bolt main one piece rear seal. I will have to read more on it. Someone was telling me to look at the valley pan for tapped something. I can’t remember exactly
  21. Mr48chev
  22. squirrel
    if you pull the intake, and look at the valley, it will have a "spider" which holds roller lifters in alignment, if it's a roller cam engine. If it's a flat tappet engine, it won't have the spider, and the bolt holes that would hold in the spider might not be tapped.
    you already know it's a 1988 engine, from the casting date code.
    The partial VIN will tell you what it came from, if you can't find the PJJ code in any listing of suffix numbers for 1988 GM vehicles. The lists available on the internet are usually only for one make, and the engine was used in several different makes. If it were from a Chevy, the partial VIN would start with the number 1, but it doesn't, so my guess is you'll probably not find the PJJ code anywhere on the internet.
  23. Lloyd's paint & glass
    Probably swirl port heads. TBI ****. Not very desirable.
