Technical Shackle bushing install tips?
Discussion in 'The Hokey Ass Message Board' started by solo_909, May 18, 2017.
  1. solo_909
    solo_909
    Hey fellas,
    So I think I may have did things a little backwards and need some help. Does anyone have and tips for installing the shackle bushings from the rear? It's a tight fit and being my first time doing this I figured someone should have some idea to make things a little easier.
    Thanks,
    George
    lothiandon1940 likes this.
  2. mediumriser
    mediumriser
    from Ohio
    Take it back apart and put the bushings in the spring and perch first.
  3. First put some jack stands under the axle, then use the jack with a small block of wood and put it under the eye. Jack it up CAREFULLY, with the pressure off of the shackle install the bushing and then the end of the shackle. Do this one side at a time and use the jack first to undo the other side.....the spring is under some pressure so watch it.
    solo_909 likes this.
  4. solo_909
    solo_909
    Won't they just pop back out when install the shackles again?
  5. Not if you do the Jack trick and if you use some rubber grease.
    With the Jack,make sure everything is square and it should slip together almost.
  6. mediumriser
    mediumriser
    from Ohio
    Na put a little lithium grease on the shackle studs. They should slide right in.
  7. lothiandon1940
    lothiandon1940
  8. solo_909 and lothiandon1940 like this.
