Hot Rods Shamrock 32 3W
Discussion in 'The Hokey Ass Message Board' started by Corn Fed, Jun 28, 2022.
  1. Corn Fed
    Corn Fed
    This past weekend I did a little horse trading with a friend and ended up with a cowl side from a ’32 3-W coupe. Once home, we were doing a little closer inspection and noticed that under the black primer there was writing. A little cleaning with lacquer thinner reviled this shamrock painted over a slightly metallic dark green body. Obviously, the car had an Olds in it at one time. From the torch marks on the lower end of the subfloor it looks to have been a channeled car sometime in its past. I wonder if it was a racer or just a hot rod. Does anyone recognize it?
    On the back side of the cowl I also noticed a couple of plugs put in place to fill an old antenna or maybe flare mount. They were caked with multiple layers of paint but I could make out the faint outline of Abraham Lincoln’s head. Some more lacquer thinner and the dates appeared. 1945 and 1915! Wheat pennies that were probably put in place in the 1950’s. Since there are some visible remnants of lead on the top of the cowl, I’m ***uming these pennies are being held on with lead too.
    Too bad the prior owner painted a normal shamrock instead of a 4 leaf clover….the poor car might have had better luck than to get cut up for parts.
  2. V8RPU
    V8RPU
    from Nor Cal
    looks like you got your two cents worth
  3. B.A.KING
    B.A.KING
    Thats cool as hell.And a great idea!!!
  4. Jalopy Joker
    Jalopy Joker
    Lucky that you found it
  5. Looks like the start of a build thread to me.
  6. JimSibley
    JimSibley
    I have always said, it only takes one part to build a car! Get to work.
    rod1 and Fogger like this.
  7. Max Gearhead
    Max Gearhead
    from Wisconsin
  8. alchemy
    alchemy
    That was the rough side. He got more parts in the pile, but will be searching for a few more before ***embly begins.
  9. dirt car
    dirt car
    from nebraska
    1945 v.j. day
  10. B.A.KING
    B.A.KING
    I need left side quarter panel for 3 w. If he just happen to have one extra layin around .................,not in use .jus sayin...............................
  11. Mo rust
    Mo rust
    E.C. likes this.
