Projects Shane's 1928 sedan thread
Discussion in 'Traditional Hot Rods' started by BAILEIGH INC, Mar 7, 2014.
  1. snopeks garage
    snopeks garage
    from macomb MI
    I like where this is going!
  2. J'st Wandering
    J'st Wandering
    If you are not familiar with shoehorning an 8BA block vs. a 59AB into a Model A, do some research. The 8BA can fit and I had one in my Model A but it is tight.
    Neal
  3. BAILEIGH INC
    BAILEIGH INC
    Alliance Vendor
    Right now I think I'm going to stick with the fenders on.
    I'm pretty freakin' excited about this motor.
    ROCKER77 and volvobrynk like this.
  4. Buddy Palumbo
    Buddy Palumbo
    I'd be excited too !
    And full-fendered ... Good to hear
    volvobrynk likes this.
  5. BAILEIGH INC
    BAILEIGH INC
    Alliance Vendor
    Keep the Hollys or run Strombergs?
  6. Buddy Palumbo
    Buddy Palumbo
    I'd have the Strombergs professionally rebuilt w/new throttle shafts & stuff & run them . It'll be reliable as a stone .
  7. louisb
    louisb
    You need some EAB heads on that flatty. [​IMG]
    --louis
  8. BAILEIGH INC
    BAILEIGH INC
    Alliance Vendor
    what is the benefit?
  9. louisb
    louisb
    They are the highest compression stock heads @ 72ccs. You can mill them some and get them close to aftermarket heads but you are limited to about .360 lift unless you mill the valve pockets. You can pick them up all day for around $100 a pair so cheap HP by raising the compression ratio. The one in the pic is destined for my AV8 one day.
    --louis
  10. louisb
    louisb
    Oh and forgot to say your sedan is turning out sweet.
    --louis
  11. BAILEIGH INC
    BAILEIGH INC
    Alliance Vendor
    OK guys......I'm going all in.....
    The 49 Flatty is going in!
  12. pinkynoegg
    pinkynoegg
    Go man go!
    Glad you found a usable flatty. I vote stromberg just because I ran a couple of holleys on one of my flatheads and HATED them. I ended up rebuilding some old chrome 97's and it runs way better now.
    Dont forget to throw a new mechanical advance distributor on there and I think she is screaming for a t5 as well!
  13. Looking good Shane
    the bead roller is grate
    the avatar is the truck I told you about
  14. BAILEIGH INC
    BAILEIGH INC
    Alliance Vendor
    Guys! Hey....Guys! Check it.....
    Jeff34, kiwijeff, ROCKER77 and 2 others like this.
  15. manyolcars
    manyolcars
    I like this 34
  16. woodz
    woodz
    Oh Yeah Shane!!!! Awesome, lookin great
  17. ROCKER77
    ROCKER77
    looking good, but I think you need to bring them headlights down a bit
  18. BAILEIGH INC
    BAILEIGH INC
    Alliance Vendor
  19. cornfieldcustoms
    cornfieldcustoms
    i told you after the build off people would be using my curl cut technique lol. at least it is Bob using it. looking good
  20. HOTRODPRIMER
    HOTRODPRIMER
    The car begs for a dropped or straight headlight bar. HRP
    ROCKER77 likes this.
  21. roseville carl
    roseville carl
    Like it a lot Shane and so will you when its finished!!!
  22. BAILEIGH INC
    BAILEIGH INC
    Alliance Vendor
    It will be dropped.....stay tunes
  23. FinnishFireball
    FinnishFireball
    Looks better after every step, keep going guys!
  24. dustdevil
    dustdevil
    from illinois
    I like it!!! You are making great progress..
  25. BAILEIGH INC
    BAILEIGH INC
    Alliance Vendor
  26. BAILEIGH INC
    BAILEIGH INC
    Alliance Vendor
    I think I will be going with black wheels and black beltline and firewall. Any suggestions on engine color? (49 flathead) I was thinking the green but Bob suggested light gold. Any thoughts out there?
  27. dumprat
    dumprat
    from b.c.
    Body color on the block with black heads, pumps, and exhaust. With a splash of stainless and chrome fasteners it should look super cl***y without looking like a restoration or a street rod.
    volvobrynk and ROCKER77 like this.
  28. olskoolrodder
    olskoolrodder
    Chop looks great!
  29. A Rodder
    A Rodder
    Can you shed a little light on this, pros & cons of this way versus others?
    Thank you, Joe
    QUOTE="cornfieldcustoms, post: 10892501, member: 48662"]i told you after the build off people would be using my curl cut technique lol. at least it is Bob using it. looking good[/QUOTE]
  30. HarborKustomSpeedShop
    from Olalla, WA
    ha you beat me to it Joe, was thinking the same thing...
    A Rodder likes this.
