I recall seeing a do***ent on using a "small diameter steel rod" as the key p***ing thru a small tube welded into the original location of the door handle? This in place of going electrical? Anyone seen this or have a pictures, etc. Thanks. John
My friend John McNally did this back in the 60s on a wild Ford pick up. IIRC the small diameter rod triggered a microswitch which in turn activated a relay that powered a solenoid. Would be hard to get enough "push" with a small rod to activate the latch mechanism.
Hmm...interesting. I see how that could work, but would think you would still end up with a visible hole and something that would get scratched every time you put the steel rod in to open the door.
If your thinking manual release of door latch with a push pin I would think Not. Once the latch is released the door has to come towards you while the latch unit is held in the open position. How you gonna get the door to come to you and out of the striker.
Back in the Old day's I had all my Door's molde'd in with a ****on on the Rocker panel. To operate the Front Doors, They worked Good until I was living in the State of Florida, Back in the Day, they told me to put the Front Handles on to get my Plates. Just my 3.5 cents Live Learn & Die a Fool
I modified an El Camino for a customer by removing the handles and leaving the lock cylinder in the door with the linkage moved to the latch , so the key activated the latch , no solenoids needed .
Again, IIRC, John incorporated the "hole" into a piece of trim so that it was not easily noticed, and bent a loop in the other end of the rod which was on his key chain. No scratches and most people don't walk around with a small diameter rod in their pockets (at least they would not admit to it) to activate the relay even if they saw the hole and figured it out.
A buddy used a magnetic switch. You just walked up to the car, touched the stainless molding in the right spot with a special magnetic key and it would activate the solenoid. Cool thing was if you didn't pay super close attention you wouldn't know how he was doing it as the magnetic key was small and unnoticeable in his hand.
There was an article and I stole a few pics, but don't remember the ***le. Credit to the Hamber that did the work & posted the pics. I have a couple more pics if interested.
