Sheet metal in illinois
Discussion in 'The Hokey Ass Message Board' started by JIMSPSYCLESHOP, May 30, 2012.
  1. JIMSPSYCLESHOP
    JIMSPSYCLESHOP
    I'm looking for a place to buy 4'X8' (or 4'X10') sheets of plain old 'black steel' in 22 gauge sheets. I live in Naperville, IL. Every place I try in my general area only supplies roofing tin or the big ones only sell to business contractors with accounts.
    I just need three sheets of sheet metal I can pay cash for, throw in my truck bed and be on my way! I want to finish my roadster and simply finding the sheet metal is holding me up. Willing to drive a ways (except in to the city of Chicago). Any Illinois guys out there that can help me with a metals supplier?
    Will to drive up to 50 miles from 60564 zip. Thanks Jimmy
  2. K13
    K13
    Can't help with a suggestion but what are you using 22 gauge hot rolled for? Awefully thin if you are doing body work and getting mill scale off is a bitch.
  3. alchemy
    alchemy
    If you want to match old Ford body-weight stuff, you need 19 gauge cold rolled. You won't find it anywhere, so get 20 gauge, which will more closely match the rust-thinned 19 gauge anyways.
  4. dontlifttoshift
    dontlifttoshift
    metal supermarkets is right down the road from us in Gurnee. Talk to Bob
  5. 56butler
    56butler
    from Illinois
    theres a place called Bobbys INC in Princeton IL about 1HR 30minutes from Naperville try calling them
  6. twisted sister
    twisted sister
    from chicago
    i think there is a metal supermarket in the elk grove area. alot closer of a drive,
  7. N A P C O IN W. Chicago. 630.293.1900
    Cosmo
  8. shane85
    shane85
  9. JIMSPSYCLESHOP
    JIMSPSYCLESHOP
    Thanks guys!
    Metalsupermarkets has a location just 24 miles from me. Going first thing tomorrow. For the record, I'm using 22 gauge because it's just the right ductile strength to form over the all wood frame of the 1919 boat tail speedster I'm building. I'll post som epics in my file once I start the skins. Jimmy
  10. Tin Can
    Tin Can
    Dimco in DeKalb, not cheap and only accepts cash or check rite off of rt 38
    Best Welding in Rochelle. Mon-Friday and has good prices rite on 251
  11. trukin55
    trukin55
    NAPCO in West Chicago as another posted. I work for a steel co. in Carol Stream. we sell aluminum and stainless, but if I needed what you are looking for, that's where I'd go.
  12. You could also try T and L manufacturing in Aurora. I know they sell steel to the public but Im not sure about sheetmetal. They would be real close to you.
  13. 2OLD2FAST
    2OLD2FAST
    from illinois
    I thought BOBBY'S in Princeton had shut down after the old man died ???
    dave
    BTW ,IF you can get it ,aluminum kilned sheet steel is wonderful to work with !!
  14. BrickTopp
    BrickTopp
  15. usmile4
    usmile4
    Connolly Steel in Naperville had what I needed in building my 51. They could probably get what you need.
  16. Hnstray
    Hnstray
    from Quincy, IL
    What you really should consider is 19ga AKDQ (aluminum killed draw quality) that is the guage most often used on earlier car bodies and the "DQ" (draw quality) part of the name offers the ductility that you are seeking and yet is thick enough to withstand various metal finishing processes that remove material, i.e. grinding, filing etc.
    This isn't just my own notion...........the spec came from metal finishing classes conducted by Ron Fournier.....a contemporary of Ron Covell.
    use the best material for the job and you will never regret it, even if it takes more effort and/or money to get it.
    Ray
