Technical Sheet metal question
Discussion in 'Traditional Hot Rods' started by Mike Colemire, Mar 6, 2021.
  1. Mike Colemire
    Mike Colemire
    What gauge of metal do most of you use for body patch panels? I've used 18 but thought maybe 20 would be a lot easier to form. Some of the complicated panels are a little tuff with the 18 but I'm no expert either.
  2. 31Apickup
    31Apickup
    I try to match the gauge of metal that I’m patching, most cases it’s 18 ga.
    4ever18 and TCATTC like this.
  3. K13
    K13
    Factory is 19 gauge so if you are thinning it at all when forming it, like wheeling, 18 is going to be closest to the original.
    Hnstray likes this.
  4. 19Eddy30
    19Eddy30
    from VA
  5. Hnstray
    Hnstray
    from Quincy, IL
    @Mike Colemire
    According to the late Ron Fournier, a life long, well respected master metal former, 19ga is what the vast majority of steel auto bodies where made from for many decades. The specific type best for metal shaping is 19ga AKDQ. That translates to Aluminum Killed Draw Quality. The 'draw quality' refers to it's elasticity for die forming without tearing, such as for oil pans or complex fender shapes, etc.
    It (DQ) is also what has usually been used for appliances, such as refrigerators stoves and washing machines, though I am not sure of the ga used for those items. It can be stretched, shrunk and bent far more easily than the typical cold roll sheet metal most often found in metal suppliers inventory. 19ga AKDQ can be obtained from metal suppliers on an order basis if they do not have it in stock.
    Another good source of metal for patch panels would be from older/other car parts that are otherwise not useable or valuable.
    Ray
    loudbang, vtx1800, Copper Top and 7 others like this.
  6. TFoch
    TFoch
    ^^^ Great info^^^
  7. Mike Colemire
    Mike Colemire
    That is good info, I'll stick with the 18.
