sheet metal work Q?
Discussion in 'The Hokey Ass Message Board' started by monstermachine, Dec 15, 2010.
  1. monstermachine
    monstermachine
    from Michigan
    I have a project in mind that involves a sand bag, mallet, mild steel sheet metal and a mig welder. My question is; What is the ideal guage steel that will form without heat and still be able to weld together without burning through?
  2. coupeman36
    coupeman36
    I work with 18 gauge cold rolled and am very happy with it.
  3. Retro Jim
    Retro Jim
    X2 !
    I use 18 ga. all the time and works great too !
    Problem is you can still burn through with a welder . When using sheet metal . just do a quick tack weld and either go to the opposite corner and criss cross the welding process and then you will start to "Stitch" weld . You can still burn thought BUT turn down to the lowest settings and try a piece of scrap sheet metal to set your wire speed .
    Hope this helps .
    Retro Jim
  4. ronk16
    ronk16
    second that, go with 18 for general purpose......
  5. Streetwerkz
    Streetwerkz
    depends on the project 18ga here for most body type panels, 16 ga for floor pans, tanks & more structural type items
    cold rolled, or pickled and oiled here
  6. BillyM
    BillyM
    I agree.......18 guage for most, but it may depend on how intricate you're going to be with the part......I'd opt for something lighter and annealled if you need to stretch and shrink very much.......and I've had better luck with higher amperage on the welds....it gets you in and out quicker!
  7. TRUCK_RAT
    TRUCK_RAT
    from tulsa
    Also remember if it isn't structural than hot rolled steel is cheaper and softer
  8. monstermachine
    monstermachine
    from Michigan
    Do most places carry hot and cold rolled?
  9. oldgoaly
    oldgoaly
    anywhere between 14ga and 24ga, try to match what the factory did, go thicker if stiffens up a body. trying to weld a 18ga to 24ga is harder than 24g to itself. Generally sheet metal shop/suppliers for the HVAC carry even number gauges, many old cars and trucks use 19ga, sometimes harder to find.
  10. long island vic
    long island vic
    im building a sleeper for my coe,,,what gauge should i use????using 1x1 or 1x2 ribbing
