Technical Shift Sequence - Aluminium Powerglide
Discussion in 'The Hokey Ass Message Board' started by blackjack, Apr 8, 2026 at 6:55 AM.
  1. I am fitting my 1957 347 Pontiac with an aluminium Powerglide from a mid 60's Impala.
    Could someone confirm the shift sequence ? Is it PNRDL or PRNDL?
    They're a bit thin in the ground over here so I can't just check...
  2. BJR
    BJR
  3. Thanks. I looked on Rock Auto for gearlever surround for a 65 Impala and that shows PRNDL.
    I want to have a sequence plate 3D printed. Might be easier to wait until I have finished the swap and just see what it does then. I'm using a Hurst Quarterstick but that won't change the sequence.
  4. squirrel
    pretty sure they switched from PNDLR to PRNDL in 1958 on Powerglides. Since the Aluminum arrived in 1962, it would be PRNDL
