Technical Shifter Handle issue/adjustment?
Discussion in 'The Hokey Ass Message Board' started by 49StreetRod, Feb 8, 2023.
  1. 49StreetRod
    49StreetRod
    from Irwin, PA
    Hey guys quick question on this shifter handle...Squeezing the handle the whole way in wont shift into all the gears, especially returning into park. Squeezing the handle just a little (say 1/4'' or so) and it slides through every gear. I can always get it in gear without any issues, really just annoying that I need to play with it. What adjustment am I missing?
    I searched but cant find any real answers other than a ton of info on the linkage, but dont think my issue is there, or is it? TH350.
  2. RmK57
    RmK57
    Trouble I had with my B&M shifter were the holes in the aluminum handle wore out really quick from constant use. They became slightly egged out and wouldn't allow the gate linkage to raise enough to shift into any gear. I made one out of steel and it's been fine for a couple years now.
    May not be your problem but something to look at. Also check out your cable adjustment?
  3. Callmaker
    Callmaker
    My bad, thought that it was something else. Csrry on...
  4. Pete Eastwood
    Pete Eastwood
    from california
    that shifter is designed for racing,
    you will be happier with a shifter designed for the street.
    seb fontana likes this.
  5. 49StreetRod
    49StreetRod
    from Irwin, PA
    I understand your steps, but what exactly is this sequence for?
