Technical shifter id
Discussion in 'The Hokey Ass Message Board' started by dukjupiter, Apr 7, 2014.
  1. dukjupiter
    dukjupiter
    looking to identify a hurst shifter
    number on stick 1931
    numbers on housing R130442
    patent #'s 3216274 3306126
    HURST 0150
    tabs on shift rods rev out 15876
    1+2 out 15374
    3+od 15875
    supposedly from mopar A833 but rods much stouter than my b-body 4 spds
  2. squirrel
    Pictures work better than numbers around here....welcome to the HAMB! also parts a little older than 1967+ (the latest patent date)
  3. dukjupiter
    dukjupiter
    tried pics, i'll try again. I gotta downsize later
  4. dukjupiter
    dukjupiter
    pictures
  5. dukjupiter
    dukjupiter
    more
  6. Root66
    Root66
    from Norcal
    Look for a 4-digit number stamped in the Reverse (longest) lever. If it is Mopar here are the numbers:
    2336= '64-'65 A & B Body
    6353= '68-'69 B Body,'68-up A body, '76-'80 F-body and truck/van with OD
    7174= '70 only B Body
    7180= '70-'74 E Body and '71-up B Body
  7. dukjupiter
    dukjupiter
    I don't see a number on there anywhere. I don't really care what its from as long as I can make it work with an A833 from a 69 roadrunner, and not going in any particular car. if it isn't for a mopar 4 speed then I guess I need to know what it is so I can sell it. I think since I removed that plate it will mount on the trans, whether the rods will work I don't know yet. any way appreciate the help, thank you
