Technical Shifter Knob Options?
Discussion in 'The Hokey Ass Message Board' started by Al T, Sep 12, 2021.
  1. My ‘58 Parisienne has a cable operated floor shifter in it and what looks like a Gen 2 Camaro/Firebird shifter knob on it. I’m hoping there is a more traditional looking shifter knob I can replace the existing one with? Maybe more in line with a C3 Corvette type shifter knob? Any suggestions would be appreciated.
    Thanks in advance.
    Allan
    87DF35B0-F615-47B1-9F18-BC2BA033121B.jpeg 7751A2A9-B0DF-43B4-942A-6C35FCAD3971.jpeg
  2. chopolds
    chopolds
    from howell, nj
    I took a similar GM shifter, made a long tube out of stainless for it, and put a large dice (die ?) on top of it, using simple tools. Even used a piece of thick plastic inside the tube, and made a ****on for one of the dice holes, to keep the lock out device.
    Driver50x likes this.
  3. Mike VV
    Mike VV
    from SoCal
    I cut off the end of an old roller camshaft, drilled and tapped it to use as a shifter handle.
    I'm not sure you'd call it traditional, or anything else for that matter !
    The imagination is a great thing.
    Mike
  4. Nailhead Jason
    Nailhead Jason
    You may be able to adapt a Lokar shifter knob to it. The issue you have is the detention in the shifter that requires the ****on to be pushed to move the lever. Lokar sells a setup that lets you screw any knob to it and push the entire knob down to release the detent for changing gears. You may want to look into that.
  5. Thanks for the replies. Lots of options. I'm leaning to see if I can thread the outside of the shaft with a die, and make a shifter knob. I'll post an update with the final solution.
    Lloyd's paint & glass likes this.
  6. Bandit Billy
    Bandit Billy
    70's F body cars (camsros and fire chickens) are some of the best supported cars in the aftermarket. There are hundreds of shift knobs made to fit that auto shifter.
    kidcampbell71 likes this.
  7. iwanaflattie
    iwanaflattie
    On my muncie
    427 sleeper likes this.
  8. Ebbsspeed
    Ebbsspeed
    Search your local craigslist or facebook for someone selling horse harness hames. A lot of them have br*** knobs which polish up real nice. Heck, you can even cut the strap loops off the steel "S" and use it for a shifter handle. The steel "S" has a very nice shape to it. 122825665_10222588640412062_2859713138512547472_n.jpg 20210913_132831.jpg 20210913_132857.jpg 20210913_132737.jpg
    Deuces, dan c, VANDENPLAS and 3 others like this.
  9. Jalopy Joker
    Jalopy Joker
    lots of options online - americanshifter.com ----- twistedshifterz.com --- etc
    Just Gary likes this.
  10. Attached Files:
  11. Deuces and 427 sleeper like this.
  12. lostone
    lostone
    from kansas
    I was wondering where the girl friend sits... now I know !!
  13. GordonC
    GordonC
    That shifter knob is crying for a flying eyeball center to be installed! Now thats traditional!:D
  14. iwanaflattie
    iwanaflattie
    Found them in grandma's night stand drawer.
    Got one in the coe and one in the econobox
  15. engine138
    engine138
    from Commack NY
    AL T what does the rest of the car look like so we can give you a direction to go in traditional of course
  16. Not a lot is going to change on it……. but I do have a replacement shifter knob ordered that is much more period correct.
    8DA094D8-C401-4C8B-8E62-4A26905CC71C.jpeg FF5B9F5E-3167-426D-ADCF-0E0D21EC9312.jpeg
    Max Gearhead, jim snow and lostone like this.
  17. engine138
    engine138
    from Commack NY
    Ok thats more like it maybe some sort of Pontiac chrome knob would fit that good
  18. lostone
    lostone
    from kansas
    Absolutely beautiful !!
  19. You can get one of these adapters that are made for automatic shift levers. The inner piece clamps onto the 'stick' with set screws and the outer piece rests on the 'reverse detent'. So the knob-of-your-choice simply screws onto the adapter and you depress the whole pumpkin to release the shifter for the forward gears.
    The threaded stud on the adapter is 16mm but there are a ton of choices in that size available. However, if you have your heart set on a particular survivor knob, send it to me and I'll put a new insert in it to fit the adapter. Just pay me for the return shipping. It's also simple to remove the adapter and revert back to original.
    I've done the knob modification a hundred or more times. It takes me just a couple of minutes.
    Al T, Jalopy Joker and jim snow like this.
  20. Jalopy Joker
    Jalopy Joker
    ^^ right guy for the right job
