Technical SHIFTiER RATTLE
Discussion in 'The Hokey Ass Message Board' started by HOTRODPRIMER, Dec 9, 2019.
  1. HOTRODPRIMER
    HOTRODPRIMER
    I have a T-5 transmission in the wagon and when I was building the car I replaced the short shifter with a modified Hurst that was a lot taller, it works great but when I have it in 5th out on the highway the shiftier seems to have a slight shake the produces a rattle, I used rubber type OE washers between the mount that comes out of the top of the transmission and the shifter, that helped some but didn't eliminate it totally, anyone else ever have this problem? HRP
    3W JOHN likes this.
  2. NewGuyOldFord
    NewGuyOldFord
    Mine was rattling on the positive stops. I adjusted them out just a hair and it went away.
    3W JOHN likes this.
  3. DDDenny
    I don't have one of those new fangled T-5 thingies Danny but I know the two new Hurst shifters I have sure are not as tight feeling as the ones we use to buy.
    Two things come to mind, check the rubber trans mount for being loose and/or seperated.
    Does the engine feel like it is "lugging" at cruise speed in 5th gear?
    3W JOHN likes this.
  4. Bandit Billy
    Bandit Billy
    Is "shiftier" some sort of French thing?
  5. HOTRODPRIMER
    HOTRODPRIMER
    No lugging in 5th gear, I'm cruising along about 55 MPH. HRP
    3W JOHN likes this.
  6. Jokester
    Jokester
    I've heard several complaints about vibrations when in overdrive on the T5. Maybe it's not the shifter!
    .bjb
    3W JOHN likes this.
  7. Jalopy Joker
    Jalopy Joker
    also, check neoprene (plastic?) bushings/washers in shifter itself - or run a small bungee cord from shifter to dash/? - Ha!
    3W JOHN likes this.
  8. Mr48chev
  9. garyf
    garyf
    If everything is mechanically correct. Some auto manufactures had a weight mounted on the tail shaft of the transmission to absorb droning that came in at certain cruise speed. They sometimes put them on a long exhaust system to absorb resonance. Droning or resonance = vibration that would rattle dash, shifter or make a tinney sounding rattle when that cruise speed point was hit.
    3W JOHN likes this.
  10. deathrowdave
    deathrowdave
    from NKy
    Lots of OEM driveshafts have harmonic balancer on the drive shaft to help with this issue . The vibration could be carrying from something connected to the trans or crossmember . My old Power Wagon , with the BT ***mins has strange harmonics from the engine vibration . It is really 100x worse than my old Harley . My thoughts to HRP , are look into a softer , set of trans and engine mounts
    3W JOHN likes this.
  11. stillrunners
    stillrunners
    from dallas
    The Cars.....it's all mixed up.....
    3W JOHN likes this.
  12. HOTRODPRIMER
    HOTRODPRIMER
    3W JOHN likes this.
  13. 3W JOHN
    3W JOHN
    Danny, have you tried figured the rattle out?
    HOTRODPRIMER likes this.
  14. Deuces
    Deuces
    :rolleyes:
  15. HOTRODPRIMER
    HOTRODPRIMER
