Sho us yer homemade english wheel...
Discussion in 'The Hokey Ass Message Board' started by Anchorboy46, Aug 29, 2008.
  1. Unkl Ian
    Unkl Ian
  2. Rods & Relics
    Rods & Relics
  3. toxictom
    toxictom
    here`s mine! build with that eastwood co.kit! not a beauty but works...
  4. Jim Stabe
    Jim Stabe
    Here's mine. 4 x 8 x 1/4" tubing, 30" throat, weighs close to 400 lbs. Home made adjuster with needle thrust bearings, home made 4340 anvils and an 8" steel caster upper about 2 3/4" wide, home made adjuster handwheel (made it with my ring roller). The wheels can be indexed to run parallel or perpendicular to the frame and I can also use a go cart slick upper or a tipping wheel and rubber anvil. I made the working height fairly high at 57" to give a better view of the work.
  5. Ram48
    Ram48
    Im know I am bring this thread back from the dead but I would like to know what you guys are using for the adjusters on the top adjuster wheels.I have a bad back and Like the idea of the adjuster on the top.
    Thanks
