Technical Shock gurus
Discussion in 'The Hokey Ass Message Board' started by solo_909, Apr 12, 2015.
  1. solo_909
    solo_909
    I need some help.
    I recently lowered my 51 Mercury using the Aerostar springs as mentioned on a thread here. They recommended using Monroe shocks but those have a different mounting type. What i'm looking for is a shock that is S4 on both ends and shorter than stock which is 8.5 compressed and 13.44 extended. I would like to be somewhere around 6.5 compressed and 11.5 extended. Anyone know where I can find something like this? Part number?
    Much appreciated,
    George
  2. lucky-13
    lucky-13
    from Sacramento
  3. solo_909
    solo_909
  4. Unkl Ian
    Unkl Ian
    Monroe has all the necessary info on their site.
  5. lucky-13
    lucky-13
    from Sacramento
  6. Unkl Ian
    Unkl Ian
  7. solo_909
    solo_909
    Thanks for the links. Monroe doesn't have anything in the length I need
  8. 54fierro
    54fierro
    from san diego
    You have a lowered ride height but doesn't the suspension still have the same range of motion/ travel?
    Wouldn't a stock length shock work? Maybe I'm missing something.
  9. solo_909
    solo_909
    Well the Aerostar springs are like 3" or more shorter than the stock one and because of that the shocks are fully compressed. So I ***ume that the shock itself needs to be shorter along with the compression.
  10. solo_909
    solo_909
    Found one!! Gabriel #81406 which is 10.4" in length vs the stock 13.5". The bottom post is a little larger but I'll just drill the mouning hole a littler larger and be good to go.
  11. Jalopy Joker
    Jalopy Joker
