I need to cut and modify some two piece, dogbone, Model A/B type shock links, in order to get both cups on the same side. What is the material? Cast steel, I hope. Thought I would ask, before I cut 'em. THANKS!
Check the parting line. A narrow parting line is cast, a wide line is a forging. I have seen them welded before.
The early version Model A-early 34 have the holes on opposite sides and the 34-35 have the holes on the same side.
Thanks! Found the new ones at Speedy Bill's. Didn't know about the 34-35's. Anybody actually welded any?
heres some I shortened. They were forged. Tig welded with mild steel rod. No problemo. Posted using the Full Custom H.A.M.B. App!
