Shock measurements
Discussion in 'The Hokey Ass Message Board' started by Alex Yohnk, Oct 7, 2010.
  1. Alex Yohnk
    Alex Yohnk
    I'm looking to get a set of shocks, around 7" compressed, 12-13" extended, and would like to get them today from a local parts store. Anybody have a list of make and models that would be in that range?
  2. Alex Yohnk
    Alex Yohnk
    or an internet resource I could use to look them up myself would work.
  3. Alex Yohnk
    Alex Yohnk
  4. Alex Yohnk
    Alex Yohnk
    dang, just went through it, and if it was the right size, it didn't have the right ends.
  5. Kinda thought you'd find that... I did.:D
  6. Alex Yohnk
    Alex Yohnk
    I really don't want to wait for speedway's.
  7. Carfanatic
    Carfanatic
    What end types do you need?? Monroe loop style 8.625" compressed 12.75" extended P/N :5752 Hope this helps.
  8. Vaya43
    Vaya43
    What is the exact mounting you need for both ends? Im guessing a bushing and sleeve top and bottom but what size I.D. does the sleeve need to have and what widths do you need? Also what vehicle are they going on and what motor is in it for aproximate valving purposes? I have several shock books I can check. Send me a pm
  9. johnod
    johnod
    There is a cross referance chart here on the HAMB. Unfortunatly i cannot attach it,cause my computer skills ****, try a search.
  10. Wildfire
    Wildfire
    late-60's SAAB has 5/8" ring ends on both and has similar dimensions - got mine at autozone for around $30 a pair. Might be the same ones Carfanatic mentioned.
  11. 55driver
    55driver
  12. Alex Yohnk
    Alex Yohnk
    It's going on the back of my '40 sedan, and the mounting points and styles are yet to be determined. The axle tubes have mounts that the previous owner put on with 5/8" studs, but I haven't fab'd the upper mounts yet. I'm actually waiting to do that until I can get a set of shocks, but some of the prelim measurements are pointing to a short shock.
  13. Alex Yohnk
    Alex Yohnk
  14. oldrelics
    oldrelics
    from Calgary
    The vintage Austin Mini's shocks worked for me. They are not gas, and have loops both ends. Nice and short.
  15. Alex Yohnk
    Alex Yohnk
    you got a part number for those?
  16. neilswheels
    neilswheels
    from England
    a 40 weighs a fair bit more than a mini. I'm having the same problem finding shocks for my 40, and i'm in the U.K!
