Technical Shock mounting
Discussion in 'Traditional Hot Rods' started by dirt t, Aug 27, 2025.
  1. dirt t
    dirt t
    7.5"x10.5" front shocks.
    Recommended mounting distance?
    Thank you for your time
    Terry aka dirt t
  2. 1971BB427
    1971BB427
    from Oregon
    1"-1.5" less than extended length to allow for rebound without topping out.
    JohnLewis likes this.
  3. dirt t
    dirt t
    7.5 compressed x 10.5 extended
  4. dirt t
    dirt t
    Thank you
  5. Mr48chev
    1.5 is right in the middle of the travel but 1.5 up or down isn't much wheel travel.
  6. 1935ply
    1935ply
    from peyton,co
    Thats minimal travel even for the ford buggy springs. With the **** roads we encounter you have to think of the occasional big bounces you will take. Might want to at least go with an 8" comp and 12" extended. Then set it with 2.5" for compression and 1.5" rebound. Even if you jam it down a couple of inches it won't rebound as much. Unless you get airborne.
  7. alchemy
    alchemy
    Be aware that a bounce of 4” at the wheel is probably only about 2/3 that at the shock.
    dirt t likes this.
  8. BJR
    BJR
    The more you angle the shock the less it moves.
    2OLD2FAST likes this.
  9. Joe H
    Joe H
    And the more you angle them, the less absorbing they do.
    GuyW and 2OLD2FAST like this.
  10. ramblin dan
    ramblin dan
    GuyW likes this.
  11. 2OLD2FAST
    2OLD2FAST
    from illinois
    GENERALLY , the expected shock travel on a t-bucket with a buggy sprung/ straight axle is about 3/4 to 1" up or down , unless you are going off roading ...
    GuyW likes this.
