Shock Mounts
Discussion in 'The Hokey Ass Message Board' started by loiselle, May 8, 2005.
  1. loiselle
    loiselle
    Ok guys, kick my ****. When you are done, maybe you can help me. I have a Model A with 350/350. I have a Mr. Roadster 4" dropped tube axle with hair pins. There are no spring perches. I am look for suggestions on lower shock mounts. Has anyone used friction shocks or lever shocks on a setup like this? If you used tube shocks, what did you use for lower shock mounts?
    Thanks.
  2. Slag Kustom
    Slag Kustom
    speedway sells lower shock mounts that go on the bottom of the pearch mount.
  3. loiselle
    loiselle
    Unfortunately, this axle does not use spring perches. The spring mount is welded to the top of the axle. Thanks anyway.
  4. joeycarpunk
    joeycarpunk
    from MN,USA
    Fabricated my own, seems to work well. Welded them to tube axle.
  5. nobux
    nobux
