Shock problem
Discussion in 'The Hokey Ass Message Board' started by Waterboychuck, Jan 3, 2013.
  1. Waterboychuck
    Waterboychuck
    I installed a 3 inch dropped axle on my 48 Ford F1 and now I'm having a problem with the steering arm hitting the shock. Does anyone know where I can buy a thinner profile shock, or the type of shock that has only a half of the tube?
    Thanks, Chuck
  2. If the attatchment is the same on both ends what about turning them upside down ?
  3. 60srailjob
    60srailjob
    from nowhere
    I had a similar problem, and didnt want to move the shock tower...went to the auto parts store told them the stroke, holes and or stem,ect and it took alittle bit but they found me a pair...give that a shot..if you dont take them the info you might as well not go....
  4. Inked Monkey
    Inked Monkey
    Are you talking about the dust shield? You should be able to find a shock that doesn't have them.
  5. F&J
    F&J
    um..:D...shocks won't work upside down.;)
    Same effect as a bottle jack tipped upside down; it won't pick up the oil, or "cycle" the oil. The shock will just feel like there is no resistance, or like a shock that lost all the oil.
  6. Fenders
    Fenders
    What I thought -- but those tend to look street-roddy...
  7. da34guy
    da34guy
    Upside down ??????
    What ya thinkin??????????
    Won't work
  8. bgaro
    bgaro
    could u bend your upper mount a bit, or cut your dust shield off maybe.
  9. Waterboychuck
    Waterboychuck
    Here are some photos that I just took. On one shock I cut the dust cover off and mounted it upside down, and the other two are shots from front and rear. It seems to be hitting the cover that goes over the steering rod. Yes, I guess I could remove that but really don't want to. I want a thin profile, or the type of shock that just has the rod at the bottom. Also I have the stock tires and rims on the truck and will be replacing them with 15 inch mags and tires that are smaller. Will that change anything?
    Thanks
  10. Old Tin and New Tin
    Old Tin and New Tin
    Build mount or bracket to move lower shock mount further outboard on the
    axle to clear.
