shock sizing?
Discussion in 'The Hokey Ass Message Board' started by EasyBake, Jun 17, 2013.
  1. EasyBake
    EasyBake
    from Bedford IN
    after lowering my 65 c10 i need shorter shocks how do I figure out what size to get?
  2. Attached Files:
  3. hotroddon
    hotroddon
    It depends on how you lowered it. Dropped spindles for instance still use stock shock lengths. You have to figure out the collapsed and extended lengths, based on the available suspension travel, and then you can use that chart that 4t64rd posted
  4. Phil1934
    Phil1934
    Measure the distance between mounting points at ride height. Find a shock that has that distance at about 40% compression so you get 60% for compression and 40% for tension.
  5. boucher racing
    boucher racing
    from nashville
    I have been down that road before, so let me help you out. I have a 1966 GMC SWB that I have lowered as much as possible with still a good ride. 1 3/4 coil off the front and the bump stop brackets removed.
    Read my post on the C10 forum, it explains how I fixed it. PM me with any questions.
    My post:
    http://67-72chevytrucks.com/vboard/showthread.php?t=573266
    Boucher'
  6. EasyBake
    EasyBake
    from Bedford IN
    Thanks man! saved me some headache!
