Technical Shocking
Discussion in 'The Hokey Ass Message Board' started by Dinger's Fiddy, Jul 27, 2020.
  1. Dinger's Fiddy
    Dinger's Fiddy
    Good morning HAMBers! Question for the 49-51 shoebox folks out there. What shocks are you running front and rear with 3" drop blocks and 1.5 coils cut from stock. I am replacing the stock front coils with cut Aerostar springs soon. Just need some socks for now. Thanks in advance!
    It's only original once!
  2. flatheadpete
    flatheadpete
    from Burton, MI
    IIRC I used a V8 Monza shock for the front on mine. Don't have the part # right off hand. BTW...cut Areostar coils ride really bad. I cut a coil on mine and have just about had it with the ride. It takes the joy out of driving when it rides that bad. Just my 2 cents....
    Dinger's Fiddy likes this.
  3. Dinger's Fiddy
    Dinger's Fiddy
    I wonder if it would be better to sell the rivets then and aim down the lower mount? I dropped my front 3" with cutting the stock spring. Stock Aerostar springs are allegedly 2.5" would a 1/2" drop cup make up for the difference or is it not as linear as I would imagine?
    I will check on the V8 monza shocks, thank you!
  4. Slopok
    Slopok
    The rear shocks remain the same as original, Aerostar springs do not need to be cut and would be way too short with bottom of A arm lowered.
