Technical shocks
Discussion in 'Traditional Hot Rods' started by Bob metke, Aug 22, 2015.
  1. Bob metke
    Bob metke
    Shocks on my 37 pickup,cheap!
  2. Bob metke
    Bob metke
    I dropped it 5 leaves,shock mounts?
  3. 5 leaves sound like a lot to take out...how does it sit?
    for shocks and kits check out Pete & JAkes
  4. Bob metke
    Bob metke
  5. Bob metke
    Bob metke
  6. geoford41
    geoford41
    from Delaware
    Use the Ch***is Engineering set up worked on My '41 Pickup & 1940 ford coupe designed to work with the CE Frong sway bar set up also. If you plan on updates on the front end other than the shocks stick with one vendor that way all the parts will work and you should not experience hic cups in the installation
    geoford41
  7. Hotrodmyk
    Hotrodmyk
    Ch***is Engineering here too. Bolt in, perfect ride, no issues whatsoever.
