Customs Shoebox/C4 Speedo cable ?.
Discussion in 'The Hokey Ass Message Board' started by flatheadpete, Feb 28, 2010.
  1. flatheadpete
    flatheadpete
    from Burton, MI
    Have a '51 Ford w/a '79 302/C4 combo. Anyone know what type of cable I need to make the stock speedo work?
  2. Flatman
    Flatman
    You should be able to use any later model speedo cable if you have the male thread on the back of the speedo housing. There are calculators online to determine which gear you need for the cable, depending on your tire size and rear end gear ratio.
    http://www.tciauto.com/Products/TechInfo/speedo_gears.asp
    Flatman
  3. flatheadpete
    flatheadpete
    from Burton, MI
    Cool. Leave it to the old flathead guys to make it work!!
    BTW....got another T in the works. '26 T Tudor. Low....long and super bad!
  4. Flatman
    Flatman
    That's great news! A T suits you better!!!
    Heyyyyy.... I'm not that old:D
    Flatman
  5. Deuce Roadster
    Deuce Roadster
    The Stock, original type ... one should work ... :)
    The end @ the transmission is the same as a C-4 one.
  6. flatheadpete
    flatheadpete
    from Burton, MI
    Like a fat kid on cake, I'm on it.
  7. Buddy Palumbo
    Buddy Palumbo
    LMFAO - that's a visual :D !!! Gotta remember that one .
  8. Worst case you can have one made, like if you had none at all? But pretty much anything that's long enough and has the threaded connections on both ends would work, they made that stuff pretty standard early on and the only real change is some later cars use a clip on the speedo end instead of a threaded spin on connector.
