Shoebox electrical help. (screwed myself...)
Discussion in 'The Hokey Ass Message Board' started by smugglerchief40, Jul 20, 2010.
  1. smugglerchief40
    smugglerchief40
    from Derry, NH
    I have a '49 Shoebox, stock Flattie with a 6volt altenator. I was trouble shooting my high/low beam switch. While taking voltage readings I let my lead touch both the outside leads of the switch (by accident). The car was running at the time, and it kinda hesitated for a sec. and then quit running. I won't start now, acting like there is no spark, battery is fully charged and car has always started well. Any ideas of where to start? Thanks.
  2. Normal Norman
    Normal Norman
    from Goshen IN.
    Wow, Has this car been rewired in a strange way? The only thing I could think of is mabey you killed the Ampmeter (if you still have one). Good Luck!!! Normal Norman
  3. smugglerchief40
    smugglerchief40
    from Derry, NH
    Ya seems wierd, car is wired normal. I look into that, thnks.
  4. rainhater1
    rainhater1
    from az
    If re wired look for a fuseable link, kills everthing
  5. Mike51Merc
    Mike51Merc
    Does the car have original wiring? The headlights were on circuit breakers under the dash. Perhaps you cooked one and it won't reset.
    You said "acting like there's no spark" so I'll assume the starter still cranks. Do the headlights work?
    Seems like you may have cooked a fusible link, even though the car didn't come with one.
  6. wildearp
    wildearp
    from tucson, az
    Circuit breakers can fail too. They can get hot and the arm falls off. If mounted vertically, the arm will then proceed to burn a hole in the case.
    You have a voltmeter, measure around and see where you have voltage and where you don't.
