Hot Rods Shoebox Ford Ball Joints
Discussion in 'The Hokey Ass Message Board' started by fredeuce, Aug 26, 2022.
  1. Can anyone tell me which ball joints are used by Jamco on their converted A arms for the 49-53 Ford Custom/Customline? This is to adapt the Ford Granada style stub axle and disc brake ***emblies. I believe they are either Moog K727 or K772.
    Can anyone help here?
  2. 55blacktie
    55blacktie
    fredeuce, I just sent a message. I hope it helps.
  3. BJR
    BJR
    Why not share it with all of us, it may help someone else with the same issue.
  4. 55blacktie
    55blacktie
    I don't want to take the liberty of making someone's private contact information public.
  5. BJR
    BJR
    Not looking for private contact info, just the fix to the problem.
  6. Can anyone out there answer this question?
  7. Mr48chev
    K727 is the lower ball joint that is used in a big number of Mopars
    https://www.rockauto.com/en/parts/moog,K727,ball+joint,10070
    K772 is the upper
    I'm thinking that both ball joints are the same size but some lowball outfits use the Uppers as lowers because they are a few bucks cheaper and that is the ones that have premature ball joint failure.
  8. Mr48Chev,
    Thanks for your information . Much appreciated.
    Regards,
    Fred
  9. Kris Kroll
    Kris Kroll
    Can you confirm if the K727 and K722 part numbers were correct replacement ball joints for the Jamco Suspension ball joint conversion arms? I can't get ahold of them or find any information or marking on the ball joints to determine the part #. Thanks!
