shoebox ford steering wheels
Discussion in 'The Hokey Ass Message Board' started by yblock292, Apr 6, 2009.
  1. yblock292
    yblock292
    Are shoebox ford steering wheels splined or keyed? I need to reclock mine and don't want to do it by adjusting the tie rod.
  2. 50 Ford 1963
    50 Ford 1963
    I'm pretty sure they're splined, but there was one larger spline on mine if I remember correctly, the wheel would only go on one way.
  3. Squablow
    Squablow
    Yeah, pretty sure that's right. If the wheel is off, your alignment is off.
  4. yblock292
    yblock292
    I just had it aligned by one of the best in town , its not off much just enough to bug me.
  5. 50 Ford 1963
    50 Ford 1963
    The "best in town" sometimes overlook the simple things... I made sure I specifically told the guys at my alignment shop that I wanted the wheel straight when they were done.
  6. utahdodge
    utahdodge
    I had the "best in town" do an off topic jeep and he turned the tie rod adjustment the wrong direction to level off the steering wheel. The jeep wouldn't turn to the right more than a few degrees. It almost caused an accident entering traffic. Shop tech. said that there was something wrong with the brand new tie rods and ball joints I installed, until I crawled under it and fixed it myself in their parking lot.
  7. Deffinately splined. I have one I am using in my '34. The one big "key" was 180deg off from my f-1 shaft. I checked it about 50 times and then filed out one spline....but I digress.
  8. dirthawker1313
    dirthawker1313
    this is how mine is on my 51..
  9. yblock292
    yblock292
    your right, gonna jack it up to night and adjust the tie ron ends.
  10. milorat
    milorat
    Splinned from 49 up....
  11. dan c
    dan c
    y-block 292 is right. just be sure to turn the tie-rod adjusters an equal amount on each side--no big deal!
  12. fordor41
    fordor41
    better think this one out. if you adjust the tie rod ends you will change the toe.Steering wheel will remain the same. Think you should be adjusting the link between the pitman arm and center link or steering arm on the spindle(drag link). Am not sure which you have.
  13. Retro Jim
    Retro Jim
    They are all splined . There is no easy way of doing it the correct way but to adjust the tie rods sleeves . That's the only way to fix your problem .
    Just remember to do it the right way ans REMEMBER to count your turns . Also Please DON'T use vice grips , channel lock or pliers to adjust them with . There is a tool to do it the right way with . You can buy them fairly cheap at HF .
    Why don't you just spend the money and have a Pro do it so you know the front end is aligned properly . If it's out that bad the front end should be re aligned .
    Retro Jim
