I have a 50 shoebox. Stock drive train. I need to replace the gasket because it's leaking. Does the pumpkin come out easily or do i need to pull the wheels and axles first? Thanks
Wheels and axles need to come out. Then it should come apart. The axle shafts don't need to come out-out. Just out enough to clear the center section. You will hear them drop out of the carrier as you pull them. Once they drop, pull them about 3 more inches, and you're good.
