Technical Shoebox Rear Gravel Pan Questions
Discussion in 'The Hokey Ass Message Board' started by Alt, Oct 12, 2021.
  1. Alt
    Alt
    from Michigan
    Couple questions about the rear gravel pan on my '50 Shoebox.
    First, it's relatively flimsy - any reason that welding a bit of reinforcement underneath (some thin flat stock) to give it some rigidity would be a bad or unnecessary idea?
    Second, has anyone welded their gravel pan to the tail pan & quarter panels to give it a permanent fix rather than bolting it on separately? Any negatives there?
  2. oldiron 440
    oldiron 440
    I think I would use metal bonding adhesive instead of welding strips, welding will cause more body work.
    I would not weld the pan on the body, it's nice to finish parts individually.
    Alt likes this.
