Technical shoebox side window trim?
Discussion in 'The Hokey Ass Message Board' started by bsummers, May 23, 2017.
  1. bsummers
    bsummers
    from Washington
    anybody know how to work the outside stainless window trim on side doors 50 showbox chopped. weld, solder, bend ? or does somebody make a replacement material that can be shaped, trim is going to be painted anyway. Thanks for any help I can get.
  2. Squablow
    Squablow
    If it's going to be painted, you can cut and weld it with a MIG welder, you could even smooth out the joints with some filler if you want. Not sure I like the idea of painted trim on there though.
    Some guys use door edge guard style flexible chrome plastic trim to do that stuff on 49-51 Mercs and Fords, although it looks kinda plastic-y, it's better than nothing. But most will take the time to cut/fit/weld the trim with stainless filler rod TIG or with stainless wire in a MIG welder, then grind/file smooth and polish. It's a lot of work. The stainless moldings, gl***, and garnishes are often more work than the actual sheetmetal work of a top chop. That's why so many are left unfinished.
  3. dan c
    dan c
    the old-school way to bend trim was to fill it with lead to prevent kinking.
  4. vtx1800
    vtx1800
    Do a search, I had the same problem when I did the stainless on the 49 in my avatar. I made a template and heat to reshape the extra pieces I scavenged off of two other cars. I made the stainless in three pieces and used the extra "join clips", can't remember the correct name. It worked but I am no great fabricator. There is a thread on here where the guy used TIG to join the pieces, HE was a craftsman[emoji1008]
