Technical Shoebox transmission hump.
Discussion in 'The Hokey Ass Message Board' started by TexasRay, Apr 28, 2017.
  1. TexasRay
    TexasRay
    A few months ago i picked up a decent 51 Shoebox, it was completely taken apart but had almost every part except the engine and ******. I'll be installing a 302 with a aod transmission. I'm almost done cutting and repairing all the rusted floor pans but i keep reading on the HAMB that the transmission hump will have to be raised.
    My question is how much would it need to be raised and does anybody have pictures that's done it? I'm looking for some visual references.
    Right now i have the body off the frame and its the perfect time to do it.
    Thanks in advanced!
    Ray
    Sent from my SM-G930T using The H.A.M.B. mobile app
  2. OLDSMAN
    OLDSMAN
    When in high school in the late 60's I built a 50 Ford with a 53 Olds engine and a 4 speed hydromatic trans and didn't have to cut the floor you can't get much bigger trans than that you will be ok
    TexasRay likes this.
  3. This is the transmission hump from Shoebox Central, and I think it would clear a big automatic (that's how they're pitched on the website). You can see that it's surrounded by factory-style sheet metal. I have to fab something to fill the gap. This was a little while ago. I've since ground off the boogers and seam sealed everything.
  4. TexasRay
    TexasRay
    That doesn't look like a big difference. Are the humps on the 49-50 cars different from the 51?
  5. My avitar has a 700-r-4 in it under the stock floor mounted on the stock crossmember. I had to put just a tinny bump for fill tube clearance. I know the 700- r is a bigger case than a Ford AOD. My 57 Ford has a 351-aod and I did nothing at all to it's floor. I'd say mount the body and set the motor/trans in it and see how it fits.
    The Wizzard
  6. junkyardjeff
    junkyardjeff
    I knew someone who cut out a 51 hump to use in a 49.
  7. F.Y.I. 51 was the first year for Ford-o-matic so they made more room for it. Totally different than 49-50 like junkyardjeff says. I still say do a test fit and see what you need.
    The Wizzard
  8. TexasRay
    TexasRay
  9. critchdizzle
    critchdizzle
    from Owasso, OK
    Having a 51 you should be fine, as @Pist-n-Broke mentioned they made the transmission tunnel bigger in '51. Only '49 and '50 cars have issues fitting an AOD.
