Technical Shooting scallops questions?
Discussion in 'Traditional Customs' started by hotrod54chevy, May 15, 2014.
  1. hotrod54chevy
    hotrod54chevy
    from Ohio
    Guys, I'll be scalloping my '54 Chevy 2 door soon and have some questions. The car's already painted black, basecoat/clearcoat. Do I tape off the scallops and clear over the whole thing and pinstripe/outline them or clear them while taped and then outline them? Or do I just make sure I mix hardener in and no clearcoat? I'll be using a white enamel on the scallops. I was also thinking maybe blue tips? How soon after spraying should I go back with the blue? Striping with 1 Shot so I'd rather do that last over clear. Thanks, guys!
  2. motorhead49
    motorhead49
    It all depends on the out come you are looking for , If you are looking to not feel the scallops when your done you will need to sand the entire panels that your scalloping mask it out base it then unmask and clear the whole panel, I have a bunch of times just masked off some scallops sanded just inside the area then base and cleared them before unmasking, then just have it striped after your done, as far as the blue tips after the white is dry to the touch (check by touching paper not the body) then dust in the blue before clear
  3. hotrod54chevy
    hotrod54chevy
    from Ohio
    Thanks!
  4. old soul
    old soul
    from oswego NY
    I would like to see some pics of this.
  5. hotrod54chevy
    hotrod54chevy
    from Ohio
    We decided to skip the blue but I did post some pics in another thread.
  6. Blue One
    Blue One
    from Alberta
    I tried shooting scallops, but they were ruined when the shell shattered :D
    After that I found it was better diving and getting them with a knife :D
    Chris Stapley and tb33anda3rd like this.
  7. Gman0046
    Gman0046
    I'm with Blue One. The only scallops I like are from the sea.
  8. john worden
    john worden
    from iowa
    Enamel will result in a thick paint film leaving a distinct edge to deal with. I suggest using base coat color instead.
