Shop Fluids
Discussion in 'The Hokey Ass Message Board' started by blowby, Jul 3, 2013.
  1. blowby
    blowby
    from Nicasio Ca
    How do you keep the end of the silicon seal tube from hardening?
    How do you spray penetrating lube on a bolt without soaking everything in a 6 inch radius?
    How do you keep from spraying yourself in the face when spraying carb orifices?
    If you put the extension tube on a can of brake clean, how long before the can gets knocked to the floor and breaks the nozzle off?
    When filling a waste oil jug from the drain pan, through a funnel, how do you know when the jug is full besides filling the funnel with nowhere for it to go?
    If you invert a rattle can to clean the tip each time, will you run out of propellant before running out of paint?
    I actually know the answer to most of these, not that I've learned to practice them, but I really would like to know about the silicon seal.
  2. 28TUDOR
    28TUDOR
    #1 Put the top back on it until it hardens then punch a hole in the other end a month later when you need it.
    #2 Spray it clean up the mess later
    #3 find the safty gl***es after the third time of spraying yourself
    #4 work in the middle of the floor like I do. Then you won't drop it, you'll just roll over it with the creeper
    #5 I thought that there was suppose to be a oil spot on the ground around that jug?
    #6 nope!
    28
  3. 327Eric
    327Eric
    #1- put the end in a bucket or can of water
  4. mrobvious34
    mrobvious34
    from Canyon, TX
    on the silicon i usually take a long bolt or screw down the tip of it, when i go to use it again i pull the bolt out and most of the hardened silicon comes with it.
  5. mashed
    mashed
    from 4077th
    I use a variation of the water trick. Find some tubing that fits snuggly over the tip and shove a dowel in one end. Put some water (or detergent) in it and cap the tip off with it.
  6. 63 Avanti 3137
    63 Avanti 3137
    #1... they sell condoms for that... (seriously)
    But they don't feel right somehow...
  7. How about losing the extension on the can of carb/ throttle body cleaner inside the throttle body and then using duct tape and a long dowel rod to fish it out.
    Took me 45 minutes to retrieve it but saved me from having to remove the throllte body from the engine.
    Now I tape the extension to the nozzle with duct tape.
  8. G-son
    G-son
    from Sweden
    #1 Who cares? Silicone should be avoided anyway, so letting it get impossible to use helps you avoid using it.
    #2 Penetrating oil doesn't penetrate very well anyway, just use heat if it's stuck or the good old oil can otherwise.
    #3 A rag over the carb does a pretty good job.
    #4 Has never happened to me. Maybe because I put them far away from the edge of the workbench?
    #5 Check before filling. Lift funnel, recheck.
    #6 Not yet.
  9. dynaflash
    dynaflash
    from South
    How do you keep the barn find car washing products from drying out between barn finds? That is what we all need to know.
  10. hotroddon
    hotroddon
    If it is non stick, What makes the Teflon stick to the Pan?
  11. mike in tucson
    mike in tucson
    from Tucson
    Can vegans eat animal crackers or gummy bears?
  12. HOTRODPRIMER
    HOTRODPRIMER
    I have always used masking tape over the end of the tube,,does it work?
    Apparently not,,I went to use it last week and it was harder than Chinese Arithmetic! :rolleyes: HRP
  13. Oldmics
    Oldmics
    Silicone tube-shove a screwdriver in the end.
    Oldmics
  14. tfeverfred
    tfeverfred
    I'm going to start having my **** pro built. That way, catastrophes like this won't get me down.:rolleyes:
  15. blowby
    blowby
    from Nicasio Ca
    Never heard of the water trick on silicon, have to try that. Thanks!
  16. ssimpala
    ssimpala
    Soooooo, I'm guessing it's a slow day at work today. :)
  17. Turbo26T
    Turbo26T
  18. 62nova
    62nova
    It's fun when the tube on the end of the carb cleaner flies off and past the ****erflies into the manifold!
  19. HOTRODPRIMER
    HOTRODPRIMER
    Trouble with that is it's almost impossible to get the screwdriver out after the silicone has hardened. HRP
  20. woodiewagon46
    woodiewagon46
    from New York
    I don't know about the rest of your questions, but as for the silicon tube I use the largest wire nut I have and seal it tight with electrical tape. It has worked so far.
  21. Al Napier
    Al Napier
    from Central CT
    >>>Can vegans eat animal crackers or gummy bears?>>>
    No, just those cheese flavored Goldfish.
    As far as silicone goes, I usually, just leave a little, maybe 1/2 inch hanging out the end of the application receptacle. That hardens to just past the end of the tip and I rip it off and use. Works for both automotive silicone and the latex caulk household stuff.
    Al in TN
  22. blowby
    blowby
    from Nicasio Ca
    It's only a matter of time now before we see "Eastwood announces, Barn Find Car and Truck Wash". Heck, a whole line of products: Barn Find Scented Air Freshener - For that 'been in the barn for years' smell.
  23. KRB52
    KRB52
    from Conneticut
    #5- buy the five (5) quart jug at your favorite auto supply dealer. Empty old oil from oil pan into favorite oil-changing catch container. Remove and replace oil filter and drain plug. Add oil from new jug to engine. Once the new jug is empty, CAREFULLY pour old oil from favorite catch container into oil jug. Replace cap on oil jug, mark as used oil with marker and recylce as appropriate for your area and application.
  24. HOTRODPRIMER
    HOTRODPRIMER
    After giving this some serious thought I came to this conclusion. HRP
