Technical Shop heat question
Discussion in 'The Hokey Ass Message Board' started by Mike Colemire, Sep 21, 2017.
  1. sunbeam
    sunbeam
    X2
  2. stuart in mn
    stuart in mn
    It may be expensive to buy firewood, but how much will it cost to go out and buy new heating equipment, get it installed, and then pay for whatever fuel that equipment uses? Think about your return on investment, how much firewood will you be able to buy for the price of that new equipment.
  3. Blue One
    Blue One
    from Alberta
    This thread is sure to be closed soon and you will probably be told to go to the garage journal. :D
    In the meantime the best way I have found to heat a shop is with a radiant tube heater using either natural gas or propane.
    They're efficient and cheap to run. (Electronic ignition- no standing pilot)
    On top of that they are sealed taking combustion air in from outside so gas fumes or painting in the shop isn't a problem.
  4. HOTRODPRIMER
    HOTRODPRIMER
    When I built my new shop in 2004 I wanted to be comfortable in an season,28 degrees or 99 degrees,so I installed a all electric heat and air system.
    I also insulated the walls & ceiling to the max,installed sheet rock and used insulated doors & windows.
    The power bill averages about 40 dollars a month. HRP
    Gammz likes this.
  5. Fortunateson
    Fortunateson
    I see somebody likes those kneeling pads from Princess Auto!
  6. southcross2631
    southcross2631
    I will ship you a load of Florida heat this winter . Shouldn't cost much for freight. Just let me know when you need it. Be careful when you open the box ,it gets out real easy.
  7. dan31
    dan31
    My old shop that i had for 20 years had no heat or air and barely any insulation . We tried burning wood ,salamander heaters and inver red heaters,all were a p.i.t.a. When i built my home shop i decided that i had enough of working like a cave man and installed a Fujitsu split air/heat unit. Its quiet, easy installation and cheap to run. The biggest problem with wood stoves is that once you walk over to it you can't seem to leave.
    LostBoy and lothiandon1940 like this.
  8. Blue One
    Blue One
    from Alberta
    :D They're cheap and when you're an old welder like me your knees don't like concrete floors so much any more ;) :D
  9. Blue One
    Blue One
    from Alberta
    And we will ship you a truck load of snow :D
  10. southcross2631
    southcross2631
    No thanks, I grew up in the U.P. of Michigan and saw my share of snow.
    We used to heat our shop up there with a double barrel stove setup .One 55 gallon drum with a fire box on the bottom and a heat exchanger barrel piped in on top of that. We burned a combo of wood and waste oil. If the shop would have been better insulated it would have been comfortable in there.
    Too many drafts and not enough insulation. Kept the frost off the tools though.
  11. JunkYardGuy
    JunkYardGuy
    Have a 24 x 32 pole barn garage with 10 ft ceiling. Very well insulated. I use a portable kerosene heater when needed and its very comfortable working all winter.
  12. I'm located on the line between Arkansas and Missouri. We can get really hot in the summer and cold in the winter. So I have a 3.5 ton heat pump cooling and heating my 30x40x10. I have invested in foam insulation as well. A tad expensive up front but I can use my shop year round and be productive when I am out there.
  13. F.O.G
    F.O.G
    from Pacific,Mo
    I heat my shop, 24x32, scissors truss with 14'6" at peak, with a FREE electric furnace from a friend
    that put a new system in his 2000 sq ft house. I use 2 of 3 heating elements and it works great. Shop
    has 2x6 walls with R-34 insulation throughout. Did I mention the furnace was FREE.
  14. Hemi Joel
    Hemi Joel
    from Minnesota
    YOu have to figure what your free time is worth. Do you want to spend hours messing with solid fuels, or do you want to spend that time enjoying your heated shop and working on your cars? I agree on the propane radiant tube. That's what I use to heat my well insulated 50x80x14' shop in central Minnesota. I used to burn wood, but that was too much time, then corn, but the price went up so much that propane is cheaper. Propane is zero time invested on my part. Do a pre-buy of the propane in mid summer for the best price.
  15. mr.chevrolet
    mr.chevrolet
    I heat the working area of my garage with a homemade waste-oil burner. electric hot water tank. not shown finished in this pic. I have a metal panel wall behind it now, with a 5 gal. jerry can plumbed to be a drip system. I also added a small blower to introduce air in the combustion chamber, but it was making the tank glow cherry red, so I don't use it much. works great, as a "for instance", one morning thermometer read 38 deg., 2 hrs later 72.
    just added more recent pics.
