Shop in thousand Oaks needed...
Discussion in 'The Hokey Ass Message Board' started by Burny, Jul 15, 2007.
  1. Burny
    Burny
    I got my eye on an old custom that's located in Thousand Oaks. I struck a deal with the current owner, contingent on having a few things checked out at a local shop before I throw down the money. Anyone out there own/run a shop there or know a good shop that could do a compression check and check out a few "problem areas" for me? HAMBer preferred and of course this is a paying deal.
    Thanks.
    -Ron
  2. 60starlinerrick
    60starlinerrick
    Starlite Rod and Kustom is located in Torrance, may want to give those guys a call. 310 328-5222.
  3. Burny
    Burny
    Thanks Starlinerrick, But that's almost an hour away from Thousand Oaks...I drove up the TO today from LB...Took me a bit over and 1:15...thousand Oaks is off the 101 almost to Ventura...The guys said he drop it off, so i want to make it as easy on him as possible...
  4. pimpin paint
    pimpin paint
    from so cal
    Hey Ron,
    OOOHHH! old kustoms make my naughty parts tingle! Post
    peek-churs a.s.a.p.
    Sorry, I don't know anyone in the valley that can help.
    S****ey Devils C.C.
  5. Burny
    Burny
    I'll post picts when it's sitting in my driveway...which may be real soon...I hope I didn't get you too excited, it's not a Barris original or Westergard or from that era. By old I meant it weas built in the early 70's...In Bellflower though...now that's not to say it looks typically 70's...actually some very tasty mild mods done...I will post picts soon
  6. Burny
    Burny
    BTT for the second shift
  7. At first I was going to recommend this: Try calling these?
    http://www.ocautoservice.com/Ventura_Cl***ics.asp
    Newbury Park is the closest to T.O.
    Then I looked in the phone book, and I'd say these 2 are your best bet, unless someone else has a first-hand rec.
    Thanks,
    Kurt
  8. Burny
    Burny
    thanks Kurt
  9. MichaelDorman
    MichaelDorman
    For a shop in T.O I would say
    The Rod Shop in Simi Valley – 805-581-8022
    Noble Fabrication in Ventura – 805-652-0595
    and for closer to you I would recomend
    Skratch's Garage – 818-768-0054 in Sunland
    Good luck and congrats!
  10. Marcy
    Marcy
    I believe Dan Collins new shop is just past Thousand Oaks in Camarillo----hit him up.
    Marcy
  11. Burny
    Burny
    thanks link!
