Projects short block sitting a while...
Discussion in 'Traditional Hot Rods' started by meticulousmatt, Aug 25, 2020.
  1. meticulousmatt
    meticulousmatt
    The info I can find for those pistons says they would put the compression ratio above 11:1 a gas station by me does sell 110 octane, but that would be expensive having to use
  2. meticulousmatt
    meticulousmatt
    I will be taking it to a shop to be safe. As far as the pistons go, the info i can find says they will produce a compression ratio above 11:1 with it being bored out and 64cc heads. A gas station by me does sell 110 octane, but that would be expensive having to use. I might switch to flat tops right away while it's at the shop.
    VANDENPLAS likes this.
  3. Matt, you can always use a large chamber head, 76cc were available as factory heads. See what C/R you'll get with that combination.
    Turnipseed likes this.
  4. gimpyshotrods
    gimpyshotrods
    If, and only if, that 11:1 information is correct, for 64cc chambers, aluminum 76cc heads may be ok.
    On a 4" bore, or thereabouts, 10cc in the combustion chamber is worth roughly 1 point in compression ratio.
    So an increase from 64cc to 76cc should put you at about 10:1. Plus aluminum dissipates combustion chamber heat better than Iron.
    Then, conventional premium fuel should be fine.
    Truckdoctor Andy likes this.
  5. UGOTBIT
    UGOTBIT
    from Upstate NY
    I would have ran it.
    Static comp is only part of the equation.
  6. gimpyshotrods
    gimpyshotrods
    He can't run it.
    He said short block, not long block.
    Short block = no heads.
    It is a partial short block, at that, because he's got no cam or lifters.
    RMONTY likes this.
  7. ekimneirbo
    ekimneirbo
    Looks like he honed it at home and didn't do a very good job. The hone looks more like a circle than a crosshatch. Don't mean to be overly critical but if thats the quality of the work the guy performed, you need to dis***emble it if for no other reason than to fix the honing.
    427 sleeper likes this.
  8. UGOTBIT
    UGOTBIT
    from Upstate NY
    I understand that, I guess a better way for me to say it would have been, I would not have dis***embled what is there.
  9. RMONTY
    RMONTY
    ^^^^^ exactly my point. Had this been honed by a machine, the crosshatch would have been uniform and pretty....something more along the lines of this....
  10. Looks like the hone job was done with a block home not a Christmas tree.
    doesn’t look horrible but not “text book” either
    don’t look bad but yes for what it’s worth take it to a machine shop
    Pistons are cheap also
    And should be able to sell these ones and recoup some cake in the process
    RMONTY likes this.
  11. RMONTY
    RMONTY
    You have a lot more faith in someone else's work than I do, not that there is anything wrong with that. And I am not skeptical by birth, people have helped me become that way!
  12. TrailerTrashToo
    TrailerTrashToo
    Words worth remembering.
  13. ekimneirbo
    ekimneirbo
    I think I was skeptical at birth and people made me worse.........:p
