Technical Short spindles - What are they?
Discussion in 'The Hokey Ass Message Board' started by van's rod shop, Jul 16, 2023.
  1. So I have these round back, no arms, early Ford spindles. I mounted them on my axle and installed the brakes and all. I went to put the drums on and discovered the spindle is too shout - only 4.5" where as a regular spindle is 5.5". It's got a full set of threads and drilled for a castle nut - it's just short! Is this
    possibly a V8 60 spindle?[​IMG][​IMG]
  2. X38
    X38
    Don't know where you got the armless spindles from, but they may have been machined for other hubs/brakes at some time. And had the arms removed.
  3. Marty Strode
    Marty Strode
    V-8 spindles are the same a 85 hp. They used 3-1/2" wheels and 550X16 tires VS 4" wheels and 600 tires on the 85.
    rod1 likes this.
  4. rusty valley
    rusty valley
    you don't show us the back side. Wasn't there just some discussion recently that early A---ar 's have round back spindles ? Dunno, not an ar expert
  5. X38
    X38
    That's obvious, because as I found out recently - probably in that same discussion - that you can get in BIG trouble for calling them AR's!!! :eek:
    rusty valley likes this.
  6. Fordors
    Fordors
    I think those spindles were modified as in the above photo to use Model T wooden spoke wheel hubs. Those hubs were six lug and would be used for pin drive or six lug racing wheels on a Midget racer.
    Carter and Max Gearhead like this.
  7. I have seen many early Ford spindles modified to be used on midget racers.
  8. 1biggun
    1biggun
    Were they modified for a set of spindle mounts wheel s originally made for for a Angla spindle ??
    I have a set of 12 spokes and that is almost exactly the mods Id need to make them work on as standard ford spindle . Turn the outer OD in a bit further and cut the ends off .
    Also wasn't the wide 5 spindle's a bit shorter one year ?? Thought I read that soem were here >
  9. It was either 1935, or 1936 that had the different length spindle.
  10. 1biggun
    1biggun
    35 had wire 16" so it must be the 36 ??
    I actually wanted to see if my 12 spokes would fit shorter spindel . I can get them on a normal ford spindel the bearing ID's are right but I have to space out the inner bearing as much as I dare to get the outer bearing to get tight on the race and the the threads stick way out . I ***ume the wheels were Anglea but maybe they fit a shorter ford spindle ?? I jsut look at the OPs set up and think if the ford bearings fit then Ibet my wheels fit them. I need a spindel abut 1/2" shorter like those .
