shorten tie rod
Discussion in 'The Hokey Ass Message Board' started by lubber, Dec 26, 2008.
  1. lubber
    lubber
    from so. calif.
    I need to shorten the tie rod on my 34 ford pickup.Can anyone tell me the tap size and thread count. I'm using original style tie rod ends. Thanks
  2. DrJ
    DrJ
    I think it's 11/16-18
    Not a common size, thanks to Henry..
    The machine supply I got mine (Cal Aero in Paramount) just calls them "Ford tie rod taps"
    (Wait for confirmation...)
  3. yoyodyne
    yoyodyne
    Yep, 11/16-18. Same as Jeep, BTW. I got right hand taps from MSC Industrial Supply but had to have the LH custom made, some years ago. Since you only need one, the RH should do.
    I hope this link takes you there. http://www1.mscdirect.com/CGI/NNSRIT?PMPXNO=1735950&PMT4NO=55693671
    If not, go to mscdirect.com and search for item # 04846762 - cost is $30.89 ea.
  4. RETROD
    RETROD
    Got mine from Speedway Motors. Fair price with shipping.
  5. lubber
    lubber
    from so. calif.
    Thanks that should get me where Ineed to go.
  6. hemi coupe
    hemi coupe
    from so-cal
    If you are close to Orange, I have the required taps to do the job. I will be at my shop tomorrow.
    Jimmy White
  7. HomemadeHardtop57
    HomemadeHardtop57
  8. lowsquire
    lowsquire
    from Austin, TX
    If they are original tierod ends, arent they female, with a male threaded rod?
    Male tierod ends started after 34..
  9. lubber
    lubber
    from so. calif.
    Thanks Jimmy ,but I'm in Palm Desert about 1:45 away.
