Shorten Your Driveshaft:
Discussion in 'The Hokey Ass Message Board' started by Drive Em, Feb 18, 2010.
  1. k32t
    k32t
    from Hog town
    cool thanks
  2. HUSSEY
    HUSSEY
    Glad this was brought back up...great tech.
  3. Scott
    Scott
    Just dug this up, Ill be using the Tech, thank you
  4. pat59
    pat59
    Great Tech here! :)
  5. '51 Norm
    '51 Norm
    from colorado
    The only drive shaft that I ever had vibration problems with was made in a machine shop. I have shortened several using a method similar to the one use by the OP and never had a problem with any of them.
  6. paul55
    paul55
    from michigan
    Great tech! Could also use a hose clamp as a guide when cutting.
  7. Nocero
    Nocero
    Been a while since I've seen this thread
    I used this method to shorten a drive shaft for my coupe
    Worked great got it down to .003 no vibration at all, and never had it balanced.
    Thanks to the original poster.
    I saved a bunch. Only cost out of pocket was a harbor freight magnetic base dial indicator.
  8. jetnow1
    jetnow1
    from CT
    You can rent the large tubing cutter from most rental places, contractors use them to cut lolly columns. Much better than trying to follow a line with a hack saw and way faster.
  9. 1-fatboy
    1-fatboy
    Getting more difficult to locate these in aby kind of shape.
