Technical Shortened 32 rolling chassis for a model A
Discussion in 'Traditional Hot Rods' started by Hotrodmeister, Feb 6, 2024.
  1. Hotrodmeister
    Hotrodmeister
    from Virginia
    Hello guys. Curious if anyone has any recommendations as to who could make a 32 rolling ch***is for a Model A that is shortened to the stock Model A wheel base? Anyone out there come to mind or does anyone reading this have the skills?
  2. 5window
    5window
    What's wrong with a beefed up Model A ch***is?
  3. Hotrodmeister
    Hotrodmeister
    from Virginia
    Those are cool too, however the 32 ch***is has a certain aesthetic and heritage to it. Hoping someone out there may be willing to build one to these specs.
  4. Just Gary
    Just Gary
    Why do that? :confused: You'd have to either:
    (a) cut 3" out of the middle of the '32 frame and splice it back together or...
    (b) move the '32 frame's front crossmember back 3".
    Outback and lothiandon1940 like this.
  5. Happydaze
    Happydaze
    I thought the whole idea was the stylish frame with the longer wheelbase. The visual heightening of the body on the 32 rails would overall I think start to look a bit stubby if the wheelbase was shortened.
    Chris
    Just Gary likes this.
  6. I think you'd be better off using the '32 wheelbase and getting/making a longer hood. Engine space is tight in a Model A. YOMV
    Kiwi 4d, big duece, dirt t and 4 others like this.
  7. lake_harley
    lake_harley
    Well, so far everyone has told the OP why his idea is flawed rather than suggesting ways or people who will make his idea possible. No, I don't have help to offer or have personal experience with people who might be able to help either, but I don't see the need to poo-poo his idea.
    Lynn
  8. 5window
    5window
    Fine, here you go. No endor*****t of the craftspeople.
    https://rjays.com/shop/ols/products...mplete-rolling-ch***is-rj-a32r?olsFocus=false
    Can we go back to questioning the concept now?
  9. 5window
    5window
    FWIW I got 32.700,000 hits in 0.25 second on the first Google search.
    flynbrian48 likes this.
  10. -Brent-
    -Brent-
    You should contact @thunderbirdesq . Andy isn't all that far from you. He can build a ch***is and so he can likely modify one for length and pinch it while you're at it.
  11. dln1949
    dln1949
    Any reputable hot rod shop that sells 32 Ford frame rails can slide the front x member back a few inches. If you are going to build the car yourself from pieces you can do it yourself, measure twice, cut once is the rule I try to follow. If you are not sold on your welding and fabrication skills, seek help for safety sake. Fenderless model a bodies on 32 ch***is look *****in, but when you put a full hood on one it does look funny with a longer hood(imho).
  12. ALLDONE
    ALLDONE
    I think, as alot of others do.. you misunderstood the concept... the reason to put a 32 ch***is under a model A if cause you want a fenderless hi boy.... and pretty sure all the hits you got was for that reason,... I owned " las vegas street rods"... we did it all the time...all you need to do is box the A frame and it will be more than enough...but, maybe that whats you are doing????? I for one, and sure others probley just need more info to under stand why??????nothing to gain for all the work
  13. ALLDONE
    ALLDONE
    ''-Stamped 32 Frame Rails Pinched for Model A body''
    -Tubular 8-Point X-Member
    -Mounting Holes Have Welded Thread Nuts
    -Choose Tube or I-Beam 4" Drop Front Axle
    -Front 4-Bar or Hairpins
    -Posie's 7-Leaf Front Spring
    -Front Rod Shocks
    -Vega Box Steering
    -Basic GM Front Disc Brakes (standard)
    -5 on 4-1/2" or 5 on 4-3/4" Bolt Pattern
    -Choose Chevy or Ford Motor & Trans Mounts
    -Dual Master Cylinder and Brake Pedal
    -Frame C-Notched in rear for Clearance
    -Rjays rear Ladder Bars (standard on all ch***is)
    -9" Ford Rear / 11" Brakes with open Third Member
    -Aldan Viper Coil-Overs or Posies Buggy Spring
    -Front and Rear Panhard Bars
    soooo..... are you gonna run fenders and a hood????
    there's a wealth of knowledge here... and a even greater amount that are willing to help...
    GlassThamesDoug likes this.
  14. ALLDONE
    ALLDONE
  15. Hotrodmeister
    Hotrodmeister
    from Virginia
    One of the primary reasons a shorter frame is desired is to accomplish a particular look. Sometimes a Model A on standard length 32 rails with an extended hood can look a bit "nosey" and the stubby appearance can look a bit tougher. Hotrods are partially a form of artistic expression. With that in mind, crafting a machine that appeals visually to the end user is imperative. The goal would be to run no fenders, and a STOCK length Model A hood. Furthermore, I believe numerous builders creating Model A's on 32 rails have utilized shorter rails, resulting in a similar appearance as I previously elucidated.
    05snopro440, X-cpe and RMcCulley like this.
  16. tomcat11
    tomcat11
  17. gimpyshotrods
    gimpyshotrods
    This can be done.
    That total is about 3-inches. This can be a tricky cut on a frame with pinched and tapered rails.
    I would see about having one made up with the rails pinched, and front crossmember moved back, followed by reworking the frame horns to blend back in. Past the crossmember they are largely just cosmetic.
    This would take away the extra space that you get from the extended wheelbase, so be aware that this would require that the firewall be reworked more, likely puting the engine where your feet need to be.
    This is why others have mentioned it.
  18. tomcat11
    tomcat11
  19. krylon32
    krylon32
    from Nebraska
    There's a thread on here by hot rod primer about model a roadsters on deuce rails. Study it be fore you do something you may regret.
  20. 62pan
    62pan
    I started to do this but got side tracked on another project. Removed 2 1/2 inches where C clamp is, frame height matches then. This moves hump in frame over rear axle. This allowed wheel well to be centered with the tire and still run a stock hood.
  21. Hotrodmeister
    Hotrodmeister
    from Virginia
    This is interesting, thank you for sharing. How does this modification impact engine fitment. I imagine there would still be adequate room for a flathead or sbc
  22. 29Sleeper
    29Sleeper
    from SoCal
    That way you won't need to move the firewall back 3-4 inches to get a V8 to fit.
    A Boner likes this.
  23. 62pan
    62pan
    I'm running a Model B so engine room is not affected.
    gimpyshotrods likes this.
  24. ALLDONE
    ALLDONE
    questions ???? will you have to cut the floor where the hump in the frame is,???? also , was your plan to run a 32 fuel tank???,,, also,... won't you still have to run a longer than model A hood??? and are you gonna run a buggy spring in the rear??
  25. 62pan
    62pan
    Plan is stock A fuel tank. Frame hump runs between subrails and quarter panels. Will use A rear crossmember. Once body position is determined rear frame will be trimmed and floor modified to cover crossmember. Still in the planning stage as another project came along.
    2FORCEFULL likes this.
  26. D-Russ
    D-Russ
    @flthd31 has a sweet 30/31 A coupe on deuce rails (he built the rails from scratch) with a 103.5 inch Model A wheelbase and I think it looks awesome. I personally don't have the time, patients or talent to build frame rails from scratch, but if I was going to shorten a deuce frame (106 inch wheelbase) to a Model A wheelbase (103.5), I'd start with a pair of aftermarket deuce rails and cut the 2.5 inches out of the straight part of the frame at the reveal where the running boards reside. Moving the front crossmember back would result in the front of the frame looking too thick.
    Here's his build thread with lots of pics of the frame construction and pics of the finished car:
    https://www.jalopyjournal.com/forum/threads/tech-build-your-own-32-frame-rails.299105/
  27. Brad Ley
    Brad Ley
    Because that's what people on here like to do.
    05snopro440, seabeecmc and Outback like this.
  28. ALLDONE
    ALLDONE
  29. ALLDONE
    ALLDONE
    "B" bangers are cool and make plenty of power with a few mods, back in the day, like 50 yrs ago, I used to take metal wheel barrows and cut them into the fire wall to make it recessed to fit small blocks... the reason everybody put chevys instead of fords, the chevys are about 3'' shorter than fords.... running 289 fords had to recess the fire wall... mine still runs the cowl tank.... like to make that go away,one engine fire is enough for me...
  30. D-Russ
    D-Russ
    Not sure where in Virginia you live, but these guys could build a deuce frame to your specifications:
    Jack Fuller or @jackandeuces in Hampton, VA
    Dan Urbanski or @ClutchDumpinDan in Fredericksburg, VA
    Ben Kopp or @koppy in Yorktown, VA
