Technical Shortening a differential Question
Discussion in 'The Hokey Ass Message Board' started by blazedogs, Dec 31, 2014.
  1. blazedogs
    blazedogs
    Doing a model A
    After you have considered all the variables such as wheels and wheel offset ,fenderless or not, frame set up etc, now you are ready to find a early model Ford differential and know the exact length you need .. I know ideally the cheapest and what makes the most sense is to check all the salvage yards and club members to find the right length . As I've searched with little success .Might this be a option, if you have found one that is in good shape, other than the fact it is too long ,have it shortened? Would this be cost prohibitive and would it result in a weaker differential ? Gene
  2. You mean narrowed?
  3. I think he means narrowed, the most cost prohibitive part of narrowing a rear end is the cost of axles. new aftermarket axles are not cheap, my last set ran me about 400 dollars.
  4. pitman
    pitman
    Suspect so, Chopped. Then consider the wheel width and offset options Blaze.
  5. If so. .. it won't have any affect on the strength of the differential.
  6. I think he means housing. Sometimes we get confused over terminology.
  7. gimpyshotrods
    gimpyshotrods
    The differential is just the guts around which the ring gear is placed, and into which the axle shafts protrude.
    Narrowing an axle housing does not affect the strength of this mechanism.
    Narrowing a housing should not affect its strength, as long as it has been done properly, in a proper jig.
    Paying to have a housing narrowed does cost a bit, but, as has been mentioned, the shorter axle shafts are what really add up.
    The best deal is to get your body, fenders (if used), and your actual wheel and tire combo all mocked-up, take a measurement of what width would be needed, and find an OEM axle that is already that width.
    prewarcars4me likes this.
  8. DERPR30
    DERPR30
    from HARVEY LA
    EASY WAY IS TO GO TO JUNKYARD & FIND AN EXPLORER REAR END WITH THE GEARS YOU NEED
    LESS THAN $200
  9. That is too easy, Maveric rears, bronco rears, Granada rears, Explorer like you said all good candidates for an A bone. GM would be Vega, Nova, S-10 to name a few.
    Overthinking has caused me to miss out on a lot in my lifetime, it is the nemesis to all hot rodders world wide.
  10. JOECOOL
    JOECOOL
    Don't be scared of Toyletta pickup rears,they make a lot of tough parts for them because of the off-road crowd. I used a later model Jeep Cherokee once, Just look there are a lot of options.
  11. 33sporttruck
    33sporttruck
