Technical Shortening a three-on-the-tree column
Discussion in 'Traditional Hot Rods' started by Jeff34, Nov 29, 2025.
  1. Jeff34
    Jeff34
    Happy Holidays!
    Question: Has anyone here shortened a column shift tube?
    One of the things I'd like to get done before the end of the year is the steering on my '29 roadster. I'm using a '40 steering box (side-steer), and I'll need to shorten the steering column so I can use the column shifter for my BW R10 OD. (side shift). I've got the steering wheel where I want it, and the shaft connected to the '40 box with U-Joints and a mid-shaft. Now that I've cut down the steering shaft where I like it, the shaft tube is too long.
    I've attached a couple of pictures of where I stand with the column.
    I figure someone here must have done column shift for their Hot Rod, but I can't find anything after a long search.
    deadbeat and LOU WELLS like this.
  2. I shortened an auto column and shift tube
    If than counts
    Jeff34 likes this.
  3. Jeff34
    Jeff34
    That counts…but doesn’t help much
    vtx1800 likes this.
  4. skooch
    skooch
    I’ve converted a couple of 3 speed column shifts to automatic over the years and they’ve ended up looking pretty close to what you have there. I’m guessing you want to get it closer to the firewall for appearance?
  5. Jeff34
    Jeff34
    I’m keeping the manual trans. Just need to shorten it.
  6. Tim
    Tim
    from KCMO
    So which part are you needing to cut down? The steering column mast/ tube?
    I’ve read it a few times and looked at the photos a few times and I’m still not 100%
    I think if that’s what you’re asking I would get the shifter arms on the column where you want it and then cut the length further up behind the bell to make the length where you want it.
    Then I suppose you need to shorten the shifter rod itself, the one running up the column to the hand control/shifter. In my mind I would remove the shifter then cut the end off the rod and then re attach it in the same manor it was stock.
    that way you don’t have a splice in the rod getting twisted.
    I’d thought about doing a 3 speed recently that way and figured I’d just start from the bottom up. Get the rods from the trans to the forks on the column and etc etc
  7. Marty Strode
    Marty Strode
    I have some info and pictures, I will post them tomorrow.
  8. gimpyshotrods
    gimpyshotrods
    Take it completely apart and shorten each component separately, and then put it back together.
    It's just metal.
    Get the bottom where it needs to be first, and get the shift rods all set up to work properly.
    Once you have that, then shorten it up top.
    RICH B, 302GMC, abe lugo and 9 others like this.
  9. That’s what I did
    Took the column apart
    Scribed reference marks on the tubes
    Shortened the tubes and tacked together
    Checked its fit and function
    Welded it up
  10. Jeff34
    Jeff34
    All great ideas! Thanks! I really don’t want to F it up, so I’m going to take my time and write it all down.
    Looking forward to any other tips and suggestions or tips I can get
    ffr1222k and Cosmo49 like this.
  11. Tim
    Tim
    from KCMO
    Another tip would be that when functioning correctly there really isn’t much force on anything while your parked with the clutch in just running it threw the gears to check for alignment/bind. So I would really suggest just tacking stuff together and checking it all together before anything gets really welded together or mounted solid.
    Deutscher and Jeff34 like this.
  12. Jeff34
    Jeff34
    So I took it apart and realized that it’s much simpler than I expected. Looks like I can take the same amount out of the outer tube and shift tube. I’ll borrow a chop saw to do that so I get square cuts, then tack them back together and check it before final welding.
    Here are some progress pics IMG_5302.jpeg IMG_5303.jpeg IMG_5304.jpeg IMG_5305.jpeg IMG_5306.jpeg IMG_5307.jpeg IMG_5308.jpeg IMG_5309.jpeg IMG_5310.jpeg IMG_5311.jpeg IMG_5312.jpeg IMG_5313.jpeg IMG_5314.jpeg IMG_5315.jpeg
  13. Budget36
    Budget36
    I’ve two? Outer column tubes, can’t recall what 35-40 they were off of, but if you cut too short, goof up, etc, I can send you one your way.
    Jeff34 likes this.
  14. Jeff34
    Jeff34
    Thanks, Budget! I appreciate the offer. I've got one spare outer tube, but no spare shift tube. I'm hoping not to F up. It's going to be a really tight fit to get this done. not much room in that area with the flathead in there and side shift plus pedals...10# of potatoes in a 5# bag
    Aaron J and Budget36 like this.
  15. Tim
    Tim
    from KCMO
    Eh it’s just metal if you cut it too short you can always cut it again lol.
    Budget36 and Jeff34 like this.
  16. Marty Strode
    Marty Strode
    Jeff, it looks like you are on your way, as others have said, scribe the shift tube before you cut it, so you can maintain the orientation. Also, I am using a Saginaw transmission, and I needed to make longer arms at the trans, as the sweep at the shift knob was only about 3" from second to high. Good luck. IMG_1842.JPG IMG_2174.JPG IMG_2184.JPG IMG_2187.JPG IMG_2188.JPG
    AVater, RICH B, Budget36 and 5 others like this.
  17. Jeff34
    Jeff34
    @Marty Strode Thanks for the pictures! Glad you mentioned scribing the shift tube. I would have forgotten to do that and had to cut it again...bullet dodged.
  18. Jeff34
    Jeff34
    Done! I cut down the shaft to a length that placed the steering wheel where I wanted it. Then I measured all the other components (several times) to figure out how much had to be removed (just over 8.5 inches). I cut the shift rod first and tack welded it back together. Then I ***embled the whole thing again and marked the outer tube. I cut that and drilled a new hole at the end.
    When welding the shift rod back together I used a drill bit to keep the orientation right.
    It all worked out in the end and I’m glad that’s finally done!
    Once I’m completely happy with it I’ll clean it all up and give it some rattle can love.
    Column drop and shift rods to the transmission are next
    IMG_5316.jpeg IMG_5317.jpeg IMG_5318.jpeg IMG_5319.jpeg IMG_5320.jpeg IMG_5323.jpeg IMG_5324.jpeg
    Oh, and when I cut the shifter rod to shorten it, a bunch of gross smelly water and oil came out.
  19. Tim
    Tim
    from KCMO
    Looks perfect!
  20. Jeff34
    Jeff34
    drop5.jpg Drop1.jpg drop4.jpg drop3.jpg drop2.jpg Mocking up my drop for the column. I cut the '29 drop to add a piece in the middle to drop it down more, and found a rubber part to take up the gap between the 2" model A drop and the 1.5" '40 column. Seems to be going well. I'll tack it up and fit it before final welding...
  21. Tim
    Tim
    from KCMO
  22. Jeff34
    Jeff34
    Thanks @Tim
