Technical Shortening Ford model A driveshaft
Discussion in 'Traditional Hot Rods' started by Mamel, Dec 9, 2017.
  1. Mamel
    Mamel
    Hey guy's
    Anybody ever shortend a model A drive shaft and torque tube?
    How should I tackle that?
  2. 55styleliner
    55styleliner
    Done many times. Lots of good reference if you use the search function on this site.
  3. ClarkH
    ClarkH
    Actually, go to Google, enter your search terms, and add the word HAMB. You will get much better results than you would using the site search.
    rfraze, Mamel and 48fordnut like this.
  4. In the 50's we used a 220 Volt arc welder and a heavy piece of Channel iron, 4 big "C" clamps 2 on each piece. Bevel the cuts, on the driveshaft bevel both sides about 3/8 to 1/2 inch. Clamp it with a small gap, start down in the bevel and weld 1/8th of it at 12 o'clock, rotate it to the opposite side across from the weld, Weld 1/8th of it at 6 o' clock, let it cool, then do the same thing at 3 o. clock ans 9 o-clock, then do the gaps the same way by doing opposite sides again let it cool between welds. It worked then it'll work now. A driveshaft shop will do it for about $500 depending on where you live.
    No respline just cut and weld.
    Mikel50 and wheeldog57 like this.
  5. alchemy
    alchemy
    What's the best way to shorten the A shaft? It's solid bar from end to end right? Did you respline one end, or retaper the other?
  6. manyolcars
    manyolcars
