Technical Shortest E-brake cables for Ford 8"
Discussion in 'Traditional Hot Rods' started by woodsnwater, Aug 30, 2016.
  1. woodsnwater
    woodsnwater
    from North Al.
    I've got an 8" rear out of a Granada in my model A project. The E-brake cables are 63" long. Does anybody know of a shorter cable that'll fit?
  2. RmK57
    RmK57
    Cut it to the length you need, drill out the ball and braze/ solder the ball back on the cable.
    LOU WELLS likes this.
  3. Nailhead Jason
    Nailhead Jason
    If your looking for new cables the lokar cables are great and you can get them in cut to fit sets that let you make it as long or short as you want.
  4. steel rebel
    steel rebel
    When I was building my roadster my neighbor was building a WWII Jeep. The Jeep call was just the right length. You might want to check into that.
  5. Relic Stew
    Relic Stew
    from Wisconsin
    Early Bronco ('66-'77) has a 50" cable on the driver side. $22 on Rock Auto.
  6. Internet
    Internet
    I always see lokar lokar lokar... I don't personally like their stuff. I use absco 370100 cables on all my builds. Should be about 20 usd and in stock at most auto parts stores.
    rdscotty likes this.
  7. 56don
    56don
    I went on NAPA's website and searched cables. There were different connections and different lengths and I ordered 2 new ones from them when I determined what would fit my application.
  8. woodsnwater
    woodsnwater
    from North Al.
    Thanks for all the good suggestions. After doing the math and considering the h***le of cutting factory cables to fit, the Lokar universal system was the way to go for me.
  9. Johnboy34
    Johnboy34
    from Seattle,Wa
