Shortest transmission
Discussion in 'The Antiquated' started by willsullivan, Apr 28, 2020.
  1. willsullivan
    willsullivan
    Howdy yall, do any of yall know which transmission is the shortest? The engine its bolting up to is an 8BA flathead v8
    Sent from my SM-G965U using The H.A.M.B. mobile app
  2. manyolcars
    manyolcars
    The 6 cylinder 55 chevy transmission is pretty small
    willsullivan likes this.
  3. 51504bat
    51504bat
    imgp0581_32b4cba62424725eec6d5e6228368283ea6eba2c.jpg Full syncro 3 speed out of a mid '60's (?) ford truck with no tail shaft?
  4. rusty valley
    rusty valley
    crosley, they are really small.
  5. 51504bat
    51504bat
    A shift tower from a Jeep is almost a direct bolt on. Sorry don't have the ****** type right now. With the tower installed the shifter is in almost the same location as a stock trans.
    Old wolf and willsullivan like this.
  6. Rusty O'Toole
    Rusty O'Toole
    30s Hudson used a small transmission.
  7. 51504bat
    51504bat
    Runnin shine likes this.
  8. 41rodderz
    41rodderz
    from Oregon
    42merc likes this.
  9. Phil1934
    Phil1934
    mid '60's Ford truck (mount below) and van 3 speed (mount above)[​IMG]
    Hnstray, willsullivan and 51504bat like this.
  10. 51504bat
    51504bat
    Don't have the tape on a SM465 but my guess is that it is shorter. But its a truck 4 speed with a granny low. The OP said he wanted to mate it to an 8ba flathead. The full syncro 3 speed would be a better unit IMO and you can either adapt it to a full car 8ba bell housing or use an adapter to a truck or Merc 1/2 bell housing.
    Old wolf, Hnstray and willsullivan like this.
  11. RICH B
    RICH B
    Chev trans adapted to a Ford torque tube is pretty short.
  12. s55mercury66
    s55mercury66
    from SW Wyoming
    The SM420 is a little shorter than the SM465, maybe an inch or two, fyi.
  13. 56sedandelivery
    56sedandelivery
    ^^^^That Muncie 318 trans has been shortened quite a bit, even to the point of losing it's speedometer drive. The shortest factory Muncie 318 would be the 58-64 X-frame car versions. I had a Gibson Model D tractor, with tiller steering once, that had an early Chevrolet 3 speed transmission with reverse. It was pretty short being a top mshift, belt driven, modified tail housing connected directly to the MOPAR rear end. These production tractors were a collage of different auto manufacturers various parts, were made in Seattle and Denver, and were pretty popular on small hobby farms. Mine also had a front snowplow blade and rear hitch. I am Butch/56sedandelivery.
  14. Mr48chev
    Automotive Stud and loudbang like this.
  15. big john d
    big john d
    from ma
    early volvo has a 4 speed about the size of a top loader with no tailshaft full syncro top mount shifter
    rusty valley likes this.
  16. I agree with using the ford full syncro three speed and the jeep shift tower. That would be hard to beat. And you will never tear it up with most flatheads.
    deucemac, loudbang and 51504bat like this.
  17. Automotive Stud
    Automotive Stud
    What's your goal exactly? A stock F1 transmission is probably as short or shorter than most of the stuff mentioned and it bolts right up.
  18. Ebbsspeed
    Ebbsspeed
    Three speed side shifted trans from behind a 215 Buick/Olds is 21 inches from the tip of the input shaft to the centerline of the U-joint. Mounting face of trans to centerline of U-joint is right at 14 inches. Full synchro.
  19. 51504bat
    51504bat
    Knowing what the OP wants to do would certainly help.
    Hotrodmyk likes this.
  20. Hotrodmyk
    Hotrodmyk
    As above, what are you doing?
  21. willsullivan
    willsullivan
    I'm doing a Honest Charlie style Flathead motorcycle, but I want to maintain a working transmission unlike the original Honest Charlie bikes
    Sent from my SM-G970U using The H.A.M.B. mobile app
  22. goldmountain
    goldmountain
    Don't think you have enough room. Here is Norm Grabowski's bike with Corvair power but there isn't any transmission that I can see. It is hooked up to an Indian military shaft drive. I remember another Corvair bike of his from the magazines that was chain drive that looked like it was hooked up to a Harley transmission but I couldn't see clearly how he did the 90 degree switchover. Good luck. Scan-190220-0001.jpg
  23. rusty valley
    rusty valley
    my friend built a v8 60 bike like charlies, but he made his own frame, long enough to keep the 60 ******, and then coupled to a 1 to 1 90 degree gear box and i forget if it was belt or chain to the rear. sorry, no pics, he moved, and i think was sold too
    42merc likes this.
  24. Mimilan
    Mimilan
    ZF transmission out of an English CF Bedford Van.
    Alloy case 4 speed, Top Shift and tough as nails [will handle 400hp easily]
    ZF also make a 5 speed which is slightly larger [4 speed L , 5 speed R ] the R/H has an Opel input shaft
  25. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    Shortie Powerglide? Like they use in REDs?
