Shorty Sparkplugs
Discussion in 'The Hokey Ass Message Board' started by Chaz, Jun 22, 2010.
  1. Chaz
    Chaz
    The sparkplugs on our small block Chevy interfere with the headers. Before I go cutting into the headers, do any of the manufacturers offer shorter plugs?
  2. 40hemicpe
    40hemicpe
    from anaheim.ca
    accel and a/c delco i am sure there are other brands i always used accel
  3. Master of None
    Master of None
    ACCEL makes "shorty" header plugs, Check summit or Jegs
  4. TrannyMan
    TrannyMan
    I am sure they still do, Accell had some.
  5. Deuces
    Deuces
    Accel does...... Not sure on the part # though...
  6. 53chieftian
    53chieftian
    yes they do but not sure what brands!
  7. 53chieftian
    53chieftian
    ok those brands!
  8. Chaz
    Chaz
    Thanks, guys. Good to know I just might make it to bonneville!
  9. TrannyMan
    TrannyMan
  10. Joe King
    Joe King
  11. staleg
    staleg
    Over at the hotrodders bulletin board they claimed that the Champion RV92YC stock # 930 and NGK BR6FS stock #4323 are just as short as the Accel shorty plugs. (4323 is for a marine application.)
    And they cost a lot less.
  12. I use and have for amost 20 years lawn mower plugs in my race and streetcars. I cross the heat range. On 383/400 /440 mopars it is also a big problem and this solves it. Autolite 2974 or 2976 is what i use . also CJ7 or CJ6. A sbchevy with double or triple bump heads uses CJ8 I beleve but double check. Now before we all start postualting how lawnmower plugs are not a good idea, you should know that one of my racers running out of my shop ran a set in his racecar for 10 years and only changed them out of shear guilt as they work very very well. And of course put the same plug number back in.
    Don
  13. staleg
    staleg
